Old 3rd March 2006, 07:13 PM   #1
Khron is offline Khron  Romania
Send a message via AIM to Khron Send a message via MSN to Khron Send a message via Yahoo to Khron
Default GC "hybrid" supply
I intend on using a "hybrid" PSU for my RevC's, as follows:
An SMPS (with a hefty tranny, ~6 cu.in) (link's on my dad's comp, i'll attach it ASAP)
Two two-stage LM338s, first stage being a conventional reg, and the second being a "super-reg" (as in http://www.neilmcbride.co.uk/preamp.html), followed by the snubber that CarlosFM recommended.
I just received my 5-sample order of LM3886s from NatSemicon, so i hope to start work ASAP
I hope that this "frankenstein" of a PSU will sound near perfection (considering the good reviews that SMPS's). Has anyone else tried anything similar???
Old 3rd March 2006, 10:13 PM   #2
Russ White's Avatar
Send a message via Yahoo to Russ White
Yes, I have tried several variations on various themes of PSUs for "My Ref" RevC, but never a SMPS. It should be an interesting experiment. Just out of curiosity, have you tried it as designed? The PSU is actually very purpose designed for the interaction with the opamps configured as they are (think PSSR). You may not feel the need to do anything else, but curiosity says "hey it would be fun to try". Certianly it is fun to fiddle. So go for it.
Cheers!
Russ
Less pulp more juice Twisted Pear Audio.
Old 4th March 2006, 08:04 AM   #3
By "have you tried it as designed" do you mean the PSU on the RevC PCB? If you do, then i haven't tried that yet.
It's just that my dad had the great idea of modding some PC PSUs that we had lying around. After we redid the windings on the power tranny, results looked promising, so we're gonna build an SMPS according to the schematic/PCB from a site i'll have to ask dad about.
I think a first reason would be costs, then weight.
A several hundred watt tranny / toroid is, to say the least, huge, not to mention sort of expensive compared to what i'm willing to spend
Old 4th March 2006, 02:16 PM   #4
The link to the SMPS, only mine will have two separate 35Vdc secondaries.
http://www.qrp4u.de/docs/en/smps_new/
Old 4th March 2006, 03:07 PM   #5
Bazukaz is offline Bazukaz  Lithuania
Send a message via ICQ to Bazukaz
LM3886 has a typical supply rejection ratio of ~100db or more.What is the reason to do a regulated supply ?
Old 4th March 2006, 04:39 PM   #6
Nordic is offline Nordic  South Africa
Nordic's Avatar
Because it sounds better.
Old 4th March 2006, 05:18 PM   #7
analog_sa's Avatar
And at what typical frequency does this happen?
Old 4th March 2006, 07:17 PM   #8
Banned
On the negative rail, up to ~100Hz.
Old 4th March 2006, 07:47 PM   #9
So, should i consider that i've received the blessing of CarlosFM?
Old 4th March 2006, 07:54 PM   #10
analog_sa's Avatar
Mmm. Probably not. Those PC SMPSs will be noisy as hell and the effort to reduce the noise will negate any cost advantage of using them. Still, your aim might not necessarily be absolute sound quality.
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
High Voltage Power Supply PCB "oopsie" Sale Geek Swap Meet 1 2nd January 2009 05:06 AM
"rule of thumb" used to determine xxVA for a power supply's transformer? CopyofAudiófilo Chip Amps 11 22nd July 2008 12:01 PM
Hybrid "SE Tube Amp Sound Style" Chip Amp idea ThorstenL Chip Amps 24 7th February 2003 06:41 AM
Audio Crafters Guild "Super Symmetric Power Supply" raincheck Digital Source 16 22nd April 2002 08:06 AM
Page generated in 0.13570 seconds (72.73% PHP - 27.27% MySQL) with 10 queries
