| Chip Amps Amplifiers based on integrated circuits |
I want to use two diodes to protect the inputs of an opamp. If I don't put a resistor in the feedback loop, does this render the protection diodes useless? Thanks, Steve. |
#2 |
Steve,
I would use two diodes. One from the positive rail to input (Cathode on rail) and one from negative rail to input (Anode on rail) This way you can not exceed the inputvoltage above the railvoltage. \Jens |
#3 |
Would this in any way affect the sound, and is this a principle you would use yourself Jens?
#4 |
Sound should be ok if the signal is well below the rail voltage (as they should be on an input terminal)
I have used this before to protect opamps for overvoltage on inputs. \Jens |
#5 |
Thanks Jens,
I've attached a more complete schematic. It's single supply. I have a low pass filter before the opamp. For the diodes, I was thinking of using 1N914s. Is that a good choice? Steve. |
| Reverse polarity protection, better way without diode. | guiseppim | Class D | 5 | 19th May 2009 07:44 AM |
| Anti-reverse-bias protection diode vs. performance | hollowman | Power Supplies | 5 | 28th September 2008 11:15 PM |
| Quick quick question ! | guitvinny | Pass Labs | 6 | 7th February 2007 04:20 PM |
| regulator protection diode | starushz | Power Supplies | 12 | 26th January 2006 02:46 PM |
| Diode question | Holger Barske | Solid State | 2 | 14th October 2002 02:44 PM |
| Page generated in 0.08389 seconds (64.43% PHP - 35.57% MySQL) with 11 queries |
