Old 28th February 2006, 09:31 AM   #1
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Default PSU caps for tweeter only GC
I have done a search but and can't seem to find if this has been discussed before.
I want to build a pair of LM3875 Gainclones that will only be used to power 8 ohm tweeters crossed over no lower than 6 kHz. And I am wondering what the optimum value would be for the power supply capacitors (on the pins of the chip).
My first thought is to stick with 1000 uF but is there anything to be gained in going a bit lower?
And I am also thinking of bypassing the electrolytics with 0.1 uF film caps!
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 28th February 2006, 10:26 AM   #2
Vikash is offline Vikash  United Kingdom
diyAudio Moderator Emeritus
Vikash's Avatar
Well if you can go low enough, then you could use better than electrolytic caps I guess. I certainly found that bypassing with 0.1 polys has huge impact.
I guess it also would depend on what PSU you're using, as you could go real small for the caps on the pins anyhow.
edit: assuming this is for a multi-way active setup, then personally I would like all amps used exactly the same. But this is just me.
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.)
Old 28th February 2006, 12:04 PM   #3
Nuuk's Avatar
You just reminded me! I will be using them with the Skynet SMPS modules. I am currently running the full-range drivers with such a set-up and the sound is wonderful so I'm going to use the same for the full-range drivers (that effectively become mid-range in the new set up) and tweeters. Woofers will also be GC (LM3886) but with linear PSU.
1000 uF works very well for the full-rangers at present so I'll probably stick with that but it should be possible to go lower with the tweeters. And as you point out Vikash, that would allow something more 'exotic' to be used if (I feel the need)!
Old 28th February 2006, 02:16 PM   #4
Banned
Nuuk, to power the tweeters you should be better using the LM3886.
The LM3875 has no mute circuit, and it produces a small turn on/off thump.
Not good if you are using the tweeters without any protection, like a series cap.
Old 28th February 2006, 05:11 PM   #5
Nuuk's Avatar
Thanks Carlos but I am planning on using protection.
Linaeum Dipole Tweeter as a Super tweeter? ktuuri Planars & Exotics 5 17th June 2008 06:52 PM
Bypass caps for tweeter GC cm961 Chip Amps 2 29th January 2004 05:51 PM
replacement tweeter caps Dave Jones Multi-Way 2 27th August 2003 06:14 PM
tweeter caps on Ariel Mark II Dave Jones Multi-Way 1 13th August 2003 06:19 PM
Caps series with tweeter nar Multi-Way 0 27th June 2002 05:16 PM
Page generated in 0.14541 seconds (68.64% PHP - 31.36% MySQL) with 10 queries
