Please check this LM3886 layout for me
Old 26th February 2006, 08:06 PM   #1
CJ900RR is offline CJ900RR  Sweden
Default Please check this LM3886 layout for me
So im trying to improw my LM3886 Gainclone and im just finished with this layout: http://www.leetmaa.se/diy/new.pdf
Can you please have a look and give me any comment's about my selected values and clear out some questions?
Partlist:
C1: 0,1 uF film-cap polypropylen
C2: 0,1 uF film-cap polypropylen
C3: 10 uF alm-cap elektrolyt
C4: 220 pF film-cap polypropylen
C5: 100 uF alm-cap elektrolyt
C6: 10000 uF alm-cap elektrolyt
C7: 10000 uF alm-cap elektrolyt
C8: 0,1 uF film-cap polypropylen
C9: 1,0 uF axiell-cap polypropylen
R1: 33 kOhm 1% 1/4W
R2: 1 kOhm 1% 1/4W
R3: 1 kOhm 1% 1/4W
R4: 39 kOhm 1% 1/4W
R5: 10 Ohm 2W
R6: 47 kOhm 1% 1/4W
R7: 2 Ohm 2W
J6 is a jumper if you dont want the mute-function.
Thank's in advance, best regards...
Old 26th February 2006, 08:10 PM   #2
Bazukaz is offline Bazukaz  Lithuania
Bazukaz's Avatar
Quite good layout.
Old 26th February 2006, 08:16 PM   #3
Bazukaz's Avatar
Just noticing what is the reason to put R5(10 Ohms) resistor between the output ? It will burn out quickly and degrade power by much.
Also, i would shorten input traces - on the board , low level signal is not shielded , so shorting the leads may decrease noise.
Old 26th February 2006, 08:42 PM   #4
R5 is there in a design from national, but at the single-supply unit paralleld with an 0,7 uH inductor. Forgott to mention the inductor. But i can take it away and ad a jumber instead.
And i think i can shorten the input traces.
Thank you. How does the other values look?
Old 26th February 2006, 08:52 PM   #5
Bazukaz's Avatar
Inductor is a good idea , but if you don't plan to use really long speaker cables , this can be left out.Adding more components than necessary may induce some other problems.
Old 26th February 2006, 09:14 PM   #6
Well im just going to use "normally" speaker-cables so i can leave that one out.
I updated the pdf-file; http://www.leetmaa.se/diy/new.pdf
Please have another look and let me know. I also updated my first post; R5 is now a jumper.
Thank you again...
Edit: I was about to edit my first post but suddenly that button is missing.
Note: R5 is now a 0 ohm's jumper
Old 26th February 2006, 09:27 PM   #7
Bazukaz's Avatar
I can see no problems with your layout.However , the only way to test is to really build lt . good luck
Old 26th February 2006, 09:35 PM   #8
Sound good
I have allready built a simular version, but this one will be better i think. Again, thank you for your time!
Please check this LM3886 layout for meHide this!Advertise here!
Please check my pcb layout! Dominique Solid State 5 15th December 2005 12:31 AM
Layout Check Sherman Tubes / Valves 9 8th December 2004 02:56 PM
PCB Layout check supereri Chip Amps 32 20th October 2003 06:01 PM
A GC Layout check. S.C Chip Amps 120 21st August 2003 04:24 AM
Copyright ©1999-2017 diyAudio
