| Chip Amps Amplifiers based on integrated circuits |
Hi there, I already asked question on ChipAmps forum , but nobody seems to know how to solve problem...
Just finished, PA100, chipamp and snuberized regulated PSU. Testing one chanel (board) everything is beautiful, rail voltage is steady +/-27V, dc-offset 15mV, testing other the same thing... Absolutely beautiful... Now the funny part, when I connected both channels(boards) to a PSU I got massive voltage drop and negative LM388 got too hot to touch... I used a single power tranny (separate windings), a single PSU, two rectifiers (ready made, rated 7A) LM388 regulators... So, every board works perfectly, but when they are both in system sh.. hits the fan... Alexw amp. http://shine7.com/audio/pa100.htm Regulated psu , nuuk's pages http://myweb.tiscali.co.uk/nuukspot...gainclone6.html
There is no spoon...there is a fork!!! |
#2 |
Did you test each board separately???
#3 | |
I want to try 'classic' PSU (no regulators, just cappacitors) but I get +/- 38 volts at rails, is that too much for 3886 (2x2 per channel)???
#4 |
LM3886 does not need a regulated power supply.Feel free to try +-38 volts(These chips can handle +-42V).However , continous operation at +-38 Volts is only considerable if your loadspeaker impedance is >=8 ohms.LM3886's has an unique Spike protection , which is annoying when turns on , but keeps output transistor array in safe temperature range.
Regards, Lukas. |
#5 |
Just tryed 'classic' (unregulated) PSU everything worked perfectly
Funny thing, regulated PSU works with 3775
#6 |
Just how much current can that regulator deliver?
#7 | |
#8 |
Yeah, thats plenty, and did you add the caps as per the datasheet for stability etc...?
Also as per usual with error checking new stuff, grab your multimeter and check every single resistor! Good luck. |
#9 |
sith, Are you monster/shine7? or did you buy his PCBs? Or did you fabricate the pcbs?
Afraid I can't help with your problem, just interested in the above. |
#10 | |
no Monster/Shine7 is AlexW from forum here, and no i didn't buy PCB , just did plain old p2p using euro board...
| My chipamp | zymurgn | Chip Amps | 25 | 3rd December 2008 05:29 PM |
| Hum to noise problem with class A chipamp | ionomolo | Chip Amps | 5 | 2nd June 2008 03:48 PM |
| Dual-mono chipamp (3886) problem - possible grounding issue | phresh | Chip Amps | 31 | 29th February 2008 03:50 PM |
| chipamp PSU problem, need help | sith | Solid State | 0 | 26th February 2006 06:24 PM |
| Page generated in 0.10312 seconds (78.67% PHP - 21.33% MySQL) with 10 queries |
