Old 23rd February 2006, 08:18 PM   #1
percy is offline percy  United States
Default What causes low frequency rolloff under load ?
When I measure the frequency response on my PC sound card using RMAA in loopback mode (line in=>line out) it measures ruler flat from 20hz-20Khz. But as soon as I put a load on it - like a headphone(33ohm) - the low freqency response starts rolling off as early as 70-80hz.
What could be the potential causes for this ? Could it be the output current capability of the output opamp ? If the opamp is capable of the output current that what could be the next possible cause ?
The output opamp is a TLV2465C http://focus.ti.com/docs/prod/folder...t/tlv2465.html
Old 24th February 2006, 04:31 AM   #2
neutron7's Avatar
does it roll off at all volume levels? or does it get worse as you increase it
Old 24th February 2006, 04:45 AM   #3
sangram is offline sangram  India
Default Re: What causes low frequency rolloff under load ?
Usually it would be the size of the output capacitor causing the rolloff.
I can't think of anything else actually.
Old 24th February 2006, 05:01 AM   #4
Default rolloff
Depending on many factors, frequency impedance, power and induction of the head phones and all the other variables. You get factor loading effect short of like a engine on a dyno 300hp at 5200RPM, but load the dyno and poof change of HP and torque due to RPM and load, same type of physics applys to electronics.
Old 24th February 2006, 06:51 AM   #5
Ouroboros's Avatar
As your sound card will be using a single +3.3v or possibly +5V rail, it will use an output coupling capacitor to block the dc bias on the output from getting to the headphone output. With low-impedance 32R phones, you'll need at least 470uF to get good LF response. The output cap on most sound cards is much lower than this, resulting in a first-order roll-off of the bass.
Old 24th February 2006, 06:56 AM   #6
AndrewT is online now AndrewT  Scotland
is the sound card intended for driving a 32ohm headphone load?
An output of 1Vrms (about31mW) is 44mA peak current.
regards Andrew T.
Old 24th February 2006, 12:14 PM   #7
Default Re: Re: What causes low frequency rolloff under load ?
No, that would cause massive amounts of distortion.
causing the rolloff. I can't think of anything else actually.
Seconded.
/sreten.
Old 24th February 2006, 12:29 PM   #8
Thank you all. Your responses deserve some more information from me. Here are some pictures of the frequency response and distortion also if that helps give a better idea.
The freq response drops equally across the entire range - with an added rolloff in the low frequency range.
The output caps are all 100uf.
I dont know the recommended output impedance of the soundcard's output but the manual does say I can connect heaphones (and there is a headphone option in the windows/soundcard driver's mixer also which I dont think is doing anything). Oh btw its a Turtle Beach Santa Cruz card.
Its almost like a classic 1st order rolloff dont you think ?
Left (white) channel is the one connected to the headphone. Right (green) is looped directly to give you can idea of both the base soundcard and under load together.
Old 24th February 2006, 12:31 PM   #9
Total THD -
Old 24th February 2006, 12:34 PM   #10
60hz imd
ESL low frequency rolloff SkySeeker Planars & Exotics 31 15th February 2008 07:50 AM
Rolloff frequency for FE206E congari Full Range 0 7th November 2005 04:30 AM
Page generated in 0.12527 seconds (76.68% PHP - 23.32% MySQL) with 11 queries
