| Chip Amps Amplifiers based on integrated circuits |
Just finished, PA100 using Alexw schematics and layout, and Carlosfm snuberized regulated PSU.
Testing one chanel (board) everything is beautiful, rail voltage is steady +/-27V, dc-offset 15mV, testing other the same thing... Absolutely beautiful... Now the funny part, when I connected both channels(boards) to a PSU I got massive voltage drop and negative LM388 got too hot to touch... I used a single power tranny (separate windings), a single PSU, two rectifiers (ready made, rated 7A) LM388 regulators... So, every board works perfectly, but when they are both in system sh.. hits the fan... Alexw amp. http://shine7.com/audio/pa100.htm Regulated psu , nuuk's pages http://myweb.tiscali.co.uk/nuukspot/...ainclone6.html
There is no spoon...there is a fork!!! |
#2 |
C'mon ppl help me out with this one!!!!
#3 |
LM3886 insulated or non-insulated, is the heat sink grounded and no insulator? PS properly connected for each channel?? Could you give more details??
#4 |
I built a similar symmetrical regulated power supply around LM338K eight years ago, it was intended to power four TDA7294 ICs. I had planned to put both regulators in the same heatsink, but that caused parasitistic oscillation issues that by that time I did't know how to solve. The only working solution that I found was to put each regulator in a separate heatsink, without any electrical coupling between them, and also without any coupling to to the case or to the heatsinks of the chip-amps.
#5 | |
| pa100 | ambed | Chip Amps | 5 | 4th August 2009 06:46 PM |
| PA100 with DC SERVO? | YFW | Chip Amps | 35 | 17th June 2007 10:17 PM |
| Single side PCB for PA100 | zafira1981 | Chip Amps | 4 | 16th May 2006 12:02 AM |
| Can you tell me how to beef up PA100? | leadbelly | Chip Amps | 5 | 21st March 2004 07:20 PM |
| Page generated in 0.09095 seconds (79.10% PHP - 20.90% MySQL) with 10 queries |
