Old 22nd February 2006, 12:29 PM   #1
senicz is offline senicz  Poland
Default My high power LM3886TF
Best sound, best power, super low price.
Old 22nd February 2006, 01:00 PM   #2
PierreG is offline PierreG  Canada
PierreG's Avatar
Very intersting.
Did you try it?
Old 22nd February 2006, 02:50 PM   #3
I tried the same output stage but with a lm1875. I had lot of oscillation problems, but I made it work.
What I couldnt make work was the same but bridged.
the output transistors were 2n3055 / mj2955
good luck!!
Old 22nd February 2006, 03:06 PM   #4
Bazukaz is offline Bazukaz  Lithuania
Send a message via ICQ to Bazukaz
What is the reason to do this ? You won't be able to use > +-40V rails anyway.Using two LMs in parralel would give better reliability / easier to build.
Also i think that 2SA1491 have too low power dissipation for reliable operation.
Old 23rd February 2006, 11:27 AM   #5
I made this project exlusively for Hi-End speakers manufacturer "EDYTON".
For the high power output you should use 2X2SA1491/2SC2580.
Old 24th February 2006, 05:31 AM   #6
Tim__x is offline Tim__x  Canada
Are those darlingtons? If not your bias current is going to be very high, Iq(3886)*Hfe(Q2).
Old 24th February 2006, 01:33 PM   #7
steven344's Avatar
Default high power gainclone
Have you ever tried this circuit
Old 24th February 2006, 01:39 PM   #8
Default Re: high power gainclone
wow.. that's a strange circuit... do you have the explanation of how it works? I cant figure out..
thanks
Old 24th February 2006, 01:54 PM   #9
steven344's Avatar
Default tracking power supplies
This is right from the national lm12 app notes,The zeners set up a regulated power supply to the lm12 as the audio increases the series pass transistors increase the voltage to to lm12,there is always no more then 39 volts between what the lm12 is putting out and the power supply rails feeding it ,its a tracking power supply,I have not tried it yet but I wonder if it would work with lm3875 or lm3886.As an example if the lm12 was putting out + 30 volt peak the + supply would increase to approx 69 volts and the negitive supply would decrease to about -9 keeping the lm12 within soa
Old 24th February 2006, 01:56 PM   #10
steven344's Avatar
Default tracking
http://www.national.com/an/AN/AN-446.pdf
Power supply:Universal AC input/ Full range,High Efficiency, and High reliability hang Vendor's Bazaar 12 24th July 2009 03:46 AM
Wanted - High Power, High Voltage, Audio Frequency Transformer Manual. kimbal Tubes / Valves 4 11th May 2009 08:05 PM
high frequency high voltage power supply... moray james Planars & Exotics 6 23rd July 2008 07:57 PM
Max power from LM3886TF Arx Chip Amps 7 5th July 2007 06:30 PM
Page generated in 0.11165 seconds (71.19% PHP - 28.81% MySQL) with 11 queries
