Unity gain buffer in front of or behind TVC?
Old 19th February 2006, 04:10 AM   #1
KT is offline KT  United States
Default Unity gain buffer in front of or behind TVC?
Hello,
I've been very interested in wiring up a TVC like the S&B TX-102 or the Dan Slagle AVC, but I'm concerned about comments I've been seeing about a slight lack of drive and impact using these units unaided (since they are passive).
I'm going to try the TVC by itself first, of course, to see if I notice this effect. But if I do, would adding a buffer help out? I realize there will be other trade-offs by adding an active stage.
Also, if I do add a buffer, is there a general consensus as to which is preferable: before or after the TVC?
Thanks,
KT
Old 19th February 2006, 12:36 PM   #2
moamps is offline moamps  Croatia
Default Re: Unity gain buffer in front of or behind TVC?
Hi KT:
I had a chance to listen to both the S&B and Sowther TVC and must say I could not hear any drive-related irregularities. IMO, such problems occur when the source has a high output impedance. So, when using a buffer, it should be placed before the TVC. The TVC, unlike other passive attenuators, does not exhibit any issues relating to output impedance.
In case you're interested, I have designed an autotransformer volume control, which I am currently using in my system. I tried the version with and without the buffer (ECC86-based) and did not notice any significant differences (nor did my friends). You may check out the TVCs at my web site.
Milan
Old 19th February 2006, 02:33 PM   #3
Hi Milan,
I'm interested in taking a look. What is your website?
Best,
KT
Old 19th February 2006, 02:37 PM   #4
Hit the www button below. Or just go to www.moxtone.com
Milan
Old 19th February 2006, 02:38 PM   #5
Nordic is offline Nordic  South Africa
Nordic's Avatar
KT, look below his post, you will see a button that says WWW... click it
Nice stuff on there, whish there was a translated version...
Old 19th February 2006, 06:11 PM   #6
Ahhh... thanks. Didn't know about the www button.
I'll have a look.
Thanks,
KT
Old 22nd February 2006, 01:29 PM   #7
wilbur-x is offline wilbur-x  Tibet
Very interesting those TVCs !
I would like to wind a TVC myself.
It would be great if you are willing to share the necessary information.
Old 22nd February 2006, 11:09 PM   #8
Hi wilbur-x:
It's not so difficult to wind an ATVC. All you need is time and patience, and perhaps a good quality transformer core. If you have a couple of old transformer laying around that you can use for building your own ATVC, you can send me a picture and their dimensions and I'll do the calculations for you.
Milan
Old 26th March 2006, 09:59 PM   #9
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Unity gain buffer in front of or behind TVC? Send a message via AIM to Peter Daniel
I finally finilized my Integrated amp with TVC front end and can definitely state that it sounds better without a buffer in front. As and integrated solution, it also does not seem to need a buffer behind.
As a source, I was using my NOS DAC with passive I/V and 0.1uF coupling caps. I tried it with a buffer and I was loosing immediacy and adding coloration.
The buffer, OTOH, worked very well with a resistor devider based volume control in front of the same amp.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 26th March 2006, 10:02 PM   #10
The amp below has bridged output, the TVC also works as phase splitter. I prefer it with single primary.
The volume is remote controlled.
www.audiosector.com
Unity gain buffer in front of or behind TVC?Hide this!Advertise here!
Simple discrete unity gain buffer tcpip Solid State 111 7th June 2007 06:55 PM
Heretical Unity Gain line stage PLUS a little gain ? yagas Tubes / Valves 7 24th January 2006 02:30 PM
Unity gain NFB speaker-buffer Skorpio Solid State 11 30th October 2005 10:28 AM
Unity Gain Tube Buffer AKSA Tubes / Valves 41 2nd January 2004 11:11 AM
Opamp + buffer, how to bypass buffer at HF for unity gain? Christer Solid State 10 29th October 2003 07:50 AM
Copyright ©1999-2017 diyAudio
