Old 15th February 2006, 06:53 PM   #1
jazzbee is offline jazzbee  United Kingdom
Default FAULTY PSU - Mixing DESK! Please Help!
Hi Guys,
I hope that you will be able to shed some light on this matter...
I just picked up a mixing desk (soundcraft studio 24) which comes with an external power supply (model cps150) & the guy who sold it to me said that the etectrolytic capacitors are blown & it would be an 'easy fix'.
Lucky I have another studio 24 desk & opened up both power supplies & found that the capacitors in the faulty PSU were swolen (the tops were bulging out) compared to my other psu.
Will I need to just change the capacitors or could this problem be more sinister than it looks??
Please see photo of faulty PSU.
Old 15th February 2006, 06:57 PM   #2
Here is another pic.
Old 15th February 2006, 07:35 PM   #3
pinkmouse's Avatar
I've fixed two or three of those looking exactly like that. In each case, there was nothing else wrong, but obviously, I can't be definite about yours without having it on a bench in front of me. Are the fuses still intact? If so, it suggests the PSU is ok apart from the caps, so swap 'em out for 105 degree rated ones rather than the 85s that are in there, (they get quite warm), plug it in and measure all the outputs before you connect it into the desk.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 15th February 2006, 07:55 PM   #4
Thanks Pinkmouse
All of the fuses are fine, nothing else seems wrong visually.
I will try replacing the caps & see how it goes.
Thanks for the advice
Old 16th February 2006, 03:41 PM   #5
Looking at the supply design from the photo, there is little else on the board as delicate as those stubby filter caps. I would think that maybe they specified just a little to close to their failure tolerance. If it were me, I would avoid a "direct" replacement and opt for a higher voltage, higher quality replacement.
Pete Willard
pw
Old 16th February 2006, 06:39 PM   #6
Stocker is offline Stocker  United States
I was going to say the same thing. Better parts.
Jesus loves you.
The ultimate mixing desk - ? brikworm Digital Source 3 19th December 2009 10:43 PM
denom pma250 amp faulty,but no faulty parts found please help homertooties Solid State 1 7th December 2008 03:58 PM
Mixing desk design argonrepublic Music 2 6th May 2005 02:57 PM
Calrec - AMS VCS desk and AMS-Neve Libra Live desk chrisbeech2 Solid State 0 15th January 2004 08:07 PM
relationship between mixing desk busses and soundcard ins karambos Instruments and Amps 4 31st August 2003 12:07 PM
Page generated in 0.09471 seconds (71.22% PHP - 28.78% MySQL) with 11 queries
