Old 14th February 2006, 07:49 PM   #1
Wynand is offline Wynand  South Africa
Wynand's Avatar
Default Inrush Current killing fuses
I'm building a LM4870 audiosector amp.
I've got the amplifier itself up and running with a temporary power supply. My problem is that the power supply I've got consist of a 500VA transformer (dual 20v secondaries) rectified seperately. With two 10000uF caps on each rail...
The inrush current is killing me.
I've got an Idea on limiting the current with a RC time delay activating relays to bypass current limiting resistors.
I'm just wondering if anyone knows of a similar or better design to look at/compare.
I must go now unfortunately but will check back tomorrow to see if anyone could help me.
Thank you to anyone who could.
PS. I have been searching for something but could not find the right circuit.
Old 14th February 2006, 08:01 PM   #2
Craig405's Avatar
I had a similar problem with a 1KVa transformer.
Relays will work switching in resistors OR..
you can use 'inrush limiters' which are beefy NTC thermistors, when they heat up they lower in resistance. Therefore your transformer can only draw full current once theyre hot.
They are cheap and really simple. Make sure they can handle your current requirements (you can parallel them up) and put them in a sensible place (they do heat up a fair bit).
I know RS have them under 'inrush limiters' because thats where i got mine.
Craig
Old 14th February 2006, 08:02 PM   #3
bikehorn's Avatar
soft start circuit?
http://sound.westhost.com/project39.htm
Old 14th February 2006, 09:11 PM   #4
Nordic is offline Nordic  South Africa
Nordic's Avatar
Wynand, you are using T-fuses right?
Old 15th February 2006, 04:58 AM   #5
quasi is offline quasi  Australia
quasi's Avatar
I developed a soft start circuit for an amp I was working on.
The schematic is here; http://www.diyaudio.com/forums/showt...687#post784687 - post 224.
The PCB layout is here; http://www.diyaudio.com/forums/showt...781#post783781 - posts 217 & 218.
I like relay contacts because they offer the ultimate in on resistance.
Use it if you want to.
Cheers
Old 15th February 2006, 04:59 AM   #6
Wynand's Avatar
I'm using 20mm fuses, slo-blow on mains input
I've seen the circuit on ESP but want something simple.
And I don't know which NTCs to choose, even after looking at some datasheets.
Old 15th February 2006, 05:16 AM   #7
Wynand's Avatar
Aswell. Ntcs work by warming up. If you put the amp off for a couple of seconds, the caps discharge, but their still hot and thus not going to stop the inrush.
Relays will work everytime.
If nobody has one I'll work on my design and try to post it.
Old 15th February 2006, 06:30 AM   #8
Electrons are yellow and more is better!
peranders's Avatar
Here we have a typical trade off:
1 Inrush current
2 We must have fuses and they should also protect, meaning they should be chosen after the load.
The question is how you solve it.
There are a couple of threads, one of them is here:
Toroid soft start
/Per-Anders (my first name) or P-A as my friends call me
Old 15th February 2006, 06:47 AM   #9
peranders's Avatar
Default Re: Inrush Current killing fuses
http://home.swipnet.se/~w-50719/hifi/sst01
http://www.hypex.nl/docs/softstart.pdf
http://lcaudio.com/index.php?page=12 in the middel of the page
Old 15th February 2006, 07:33 AM   #10
For those who are facing the problem of inrush current, here is a link to the solution Amp Protection Circuit - Here! which in addition protects speaker thumps, detects DC to cut off speakers and has thermal protection if you wish to add.
Sam
inrush current doktor Solid State 123 20th February 2012 02:26 AM
5Z4 inrush current too high Craig405 Tubes / Valves 10 3rd September 2007 07:58 PM
CL-60 Inrush Current Limiter ljozsef Pass Labs 8 11th February 2004 09:40 PM
inrush current Jules Tubes / Valves 8 26th December 2003 05:38 AM
About Inrush Current JDeV Parts 0 2nd December 2002 06:40 AM
Page generated in 1.62192 seconds (7.72% PHP - 92.28% MySQL) with 11 queries
