Old 16th February 2006, 09:44 AM   #11
myanmar is offline myanmar  Myanmar
myanmar's Avatar
Um, did you mistype? Neither TDA2030 nor TDA2050 can withstand +/-45 rails. Max is +/-25V.
Output voltage is max +/- 25~30 V.
My power supply drop to +/- 16V too.
Normal Power supply is +/- 22.5V.
Sorry for mistake.
Old 7th March 2006, 01:57 PM   #12
sivan_and's Avatar
Send a message via Yahoo to sivan_and
myanmar wrote:
Yesterday I tested with no load.( not attach spk )Because I want to know maximum output voltage.
Voltage swing above 30V.
But My BPA burn out.
Why?
OSCILLATIONS !!!
SivanandBalan
Old 21st March 2006, 09:24 AM   #13
myanmar's Avatar
OSCILLATIONS !!!
Is that sure?
How can I test?
How can I protect?
How can I repair?
Another Bridge design
I already tested TDA2050 bridge amplifier with (TDA2030 bridge ST Design)
Circuit cannot work with TDA2050 ( supply voltage above +/- 20 V )
Only work at low supply voltage.
What is that problem?
Oscillation?
Pls, Help me.
Old 17th June 2006, 12:02 PM   #14
myanmar's Avatar
Hello Friends.
Here is my bridge amplifier.
Used TDA2030
Did you see GIGABYTE AMP ?
U can see in photo.
Old 17th June 2006, 12:04 PM   #15
myanmar's Avatar
Nest photo
Old 11th March 2007, 09:02 AM   #16
Default Schematic
Can someone give me a schematic for the bridge application of TDA2050?
How easy is it to bridge vs parallel? Ulew Chip Amps 16 1st February 2009 12:53 PM
Parallel Bridge? rgrayton Chip Amps 16 20th January 2009 03:50 PM
Bridge or Parallel? Roushon Chip Amps 71 16th September 2006 06:47 PM
OPA549 x 8, bridge/parallel soundNERD Chip Amps 2 14th March 2005 09:50 PM
parallel or bridge rulezzz Chip Amps 1 8th January 2004 06:59 PM
Page generated in 0.10396 seconds (68.71% PHP - 31.29% MySQL) with 11 queries
