Old 12th February 2006, 06:54 AM   #1
dfdye is offline dfdye  United States
dfdye's Avatar
Default Power supply design challenge!
Any of you that have read the dumpster dive thread know by now that I have come across a ~2KVA CT isolation transformer for free! I would love to use this in a psu for the LM4702 based amps I am planning, but the rectified voltage will be higher than what I was aiming for. By my math, I can expect ~+/-85V rails using a "traditional" bridge/cap non-regulated PSU, but for this project I was thinking ~+/-50V would be closer to my target. I would think that using a simple voltage divider would be pretty inefficient (), so I am trying to get a few ideas from more experienced power supply builders.
AudioFreak suggested a choke input power supply that would pump out ~51V, but I was under the impression (after reading the few internet references I could find, coupled with the fact that I may not know exactly what I am looking for) that this sort of PS was used primarily in tube amps or for higher voltage applications. Would this configuration be appropriate for an LM4702 type system, or is there some other option for getting the voltage from this transformer dropped down a little? Also, I have only come across a couple of schematics for choke input power supplies, and they are for higher voltage supplies (around 4k). If anybody has some suggestions as to whether a design of this type would be appropriate, and where I could read some more to intelligently go about building a power supply, I would greatly appreciate it!
Thanks!
David
Old 12th February 2006, 08:10 AM   #2
AndrewT is online now AndrewT  Scotland
try splitting the turns to give less voltage, about half voltage in each. Then add more turns to each winding to bring each of them up to the voltage you want. Use the same wire thickness.
You will end up with four secondaries. Run two secondaries into one rectifier for the left channel. Run the other two secondaries to another rectifier for the right channel.
regards Andrew T.
Old 12th February 2006, 09:09 AM   #3
lineup is offline lineup  Sweden
lineup's Avatar
When using regulated power supply for power amp
best NOT to have too much voltage drop across Regulator.
In other words,
if your power amp needs 50 Volt DC, get a transformer that fits.
Something like 7-12 Volts for the regulator
would give a transformer that have 57-62 Volt DC output.
lineup
Old 12th February 2006, 09:28 AM   #4
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
The only practical solution that comes to my mind now is a siwtching regulator, either a 100Hz thyristor controlled one to chop the 50Hz sine wave (similar to the ones found in Carver amplifiers), or a HF buck regulator (plain SMPS stuff, but then again, the 50Hz transformer may be also discarded in favour of a HF one).
Old 12th February 2006, 10:34 AM   #5
Banned
Add some turns to the primary until you have the voltage you need on the secondaries.
Old 12th February 2006, 11:31 AM   #6
Bazukaz is offline Bazukaz  Lithuania
Send a message via ICQ to Bazukaz
I would just unwind some secondaries , if is possible.
Old 12th February 2006, 11:53 AM   #7
duelbox is offline duelbox  United States
Forget what I said below, like I said I am tired. However this may
be of some interest. Here are some basic rules for resistive,
capacitive and inductive voltage dividers. It is possible that one of
these may be of some use.
I spoke before I thought it through, I can do that very well
sometimes
Well lets make an assumption (I know its not good to '***-u-me' anything) that ~42VDC would do the job. What about capacitively coupling between the +VDC and 0VDC for positive, then between -VDC and 0VDC for the negative? Looks like it would get around the problem of not being able to 'adjust' the windings (if in fact that is a problem with his transformer) and much more efficient than the voltage divider. It should only require four capacitors but I do not have any figures for what the specs should be.
---------------o +
-----------------------------o 1/2 +
---------------o 0
-----------------------------o 1/2 -
---------------o -
Seem reasonable? It's late and I'm tired.
(looks like it took out my white space but my simple diagram should still be legible)
Old 12th February 2006, 02:00 PM   #8
THe multiplier for a capacitive input power supply is 1.414
minus diode drops. We are all very familiar with this one.
The multiplier for Choke input is 0.90 minus diode drops.
Seems to me this puts it right where you want to although you could get a further drop by series connecting diodes if needed.
I do not believe this is only for high voltage power supplies.
The only downside is you would have to buy 2 chokes but you would have a PS of superior regulation.
Audio freak was right
Sheldon D
Old 12th February 2006, 02:06 PM   #9
the other thing to consider is the load current must be high enough to have the choke supply the current required, else the
voltage will approach the capacitor input voltage.
Sheldon D
Old 12th February 2006, 02:22 PM   #10
Dave Cigna's Avatar
I can't think of any reason that a choke input supply couldn't be used here (but I can't think of everything ) The reason they are more common in tube amps probably has as much to do with era than anything else. They provide good regulation without active regulation, but these days (and at lower voltages) I suspect that active regulation is cheaper and looks better on paper. OTOH, in the case of tube amps I have found that a simple choke input supply usually sounds better. Chip amps seem to respond well to simpler supplies, so I suspect that they might sound better with choke input than active regulation. (I won't pretend to understand why, but that doesn't keep me from using the knowledge.)
Anyway, there are a couple of criteria that need to be met in order to keep a choke input supply from acting like a cap input supply. In other words, to keep the voltage from rising. In technical terms, you need to keep the diodes conducting during a full 180 degrees of each 60Hz cycle. If they conduct only during part of the cycle to keep the caps charged then the supply voltage will go up as it starts to act like a cap input.
In practical terms, it means that you need to makes sure the choke is big enough and that you always draw enough current. The old rule of thumb is that the inductance of the choke needs to be at least:
L > V/I
where I is in milliamps (a throwback to high voltage, low current supplies.) Anyway, you can see that if you draw more current (bigger I) then you can get away with a smaller choke.
As an example, with V=50 and I = 500mA you need a choke that is at least
L > 50/500 = .1 henry or 100mH
Typically, if your choke is close to the lower limit then you would want to add bleed resistors from each rail to ground to make sure that the minimum current is always being drawn from the supply.
You could use one choke between the center tap and ground. You could use two chokes, one in each rail (the inductances will add) or you could use a dual winding choke with one winding in each rail.
Hope that's enough to get you started thinking at least.
-- Dave
48 VDC/10 A power supply looking for an Amp design Analog Addict Solid State 16 16th January 2008 10:39 AM
need help with a power supply design lochness Power Supplies 1 31st October 2007 05:12 PM
Design Challenge #1 kgillies Subwoofers 12 13th June 2007 03:20 PM
Design Challenge #2 kgillies Subwoofers 3 12th June 2007 06:05 AM
Speaker design challenge: 105db 20 - 20k at listening position paulspencer Multi-Way 28 9th July 2005 10:12 AM
Page generated in 0.14379 seconds (79.18% PHP - 20.82% MySQL) with 11 queries
