Old 8th February 2006, 02:59 AM   #1
sam9 is offline sam9  United States
sam9's Avatar
Default Question re LM4780 inverting configuration
The inverting circuit decribed in the LM4780 says that the value of Rb, the non-inverting ground resistor, should equal the parrallel value of Ri and Rf, the gain setting resistors. No problem. However, I'm curious - in the experience of those who have tried it, how critical is this match and what is the effect of a a mismatch.
The obvious compulsive-obsesive solution is to use two parrallel resistors for Rb having the same values as Ri and Rf. But how critical is this in real ife?
Old 8th February 2006, 08:41 AM   #2
sangram is offline sangram  India
Why not try it out?
Actually I have, but not with LM4780.
My first 'chip'amp was a 4-way TDA2030 circuit, 2 chips per channel in bridge configuration. I used the single resistor bridge method for simplicity, one of the main goals of the circuit at the expense of sound quality. The chips were all in inverting configuration with Rb=Ri.
I don't remember any problems with DC-offset.
The second time I have tried inverting configuration with LM4766 P2P wiring, I paralleled the resistors because I could.
I think you may not face any problems apart from a slightly higher than usual DC-offset. If that.
Old 8th February 2006, 01:58 PM   #3
sam9's Avatar
After posting, it also ocurred to me that using a small trim pot for Rb might be a possability if DC offset is the main concern.
Old 8th February 2006, 02:03 PM   #4
Bazukaz is offline Bazukaz  Lithuania
Send a message via ICQ to Bazukaz
Resistor mismatch would set slightly different gaint for each IC. I used 5% metal film resistors without any problems.You can match resistors with ohmetter.
Old 8th February 2006, 02:36 PM   #5
sam9's Avatar
Bazukaz,
I was concerned not with the gain setting resistors but with the resistor between non-inverting input and ground. The AppNotes say this should be the same value as the value you would get if the gain setting resistors were parralleled.
If Rf//Ri = 20k//1k= 953 I.e., A=20), then Rb should be 953. This is all very neat. But if you are using different Rf and Ri an exact Rb is hard to find. Exact alternatives are
Rf=200k
Ri=10k
Rb=9.53k
or 2k, 1k, 93.5 etc. If you want a gain other than 20 is also gets tricky. While you can generally find a Rb within 1% of the desired value exact, I was curious about how sensative the device was to mis matches. Sometime a mis match of 0.5% can be important sometime 5+% is a matter of indifference.
I can try it myself of, course and it looks likley I will have to but I thoght to save some time.
sonic differences between inverting/non-inverting LM4780 VS both non-inverting LM4780 jarthel Chip Amps 5 19th July 2007 01:37 PM
Bridged/Stereo, w or w/o servo, inverting 3886, inverting buffer PCB Alexander Rice Chip Amps 9 27th March 2004 07:53 PM
Multiloop and inverting configuration martioz Solid State 14 11th March 2003 07:31 AM
Question about d'appolito configuration Leeuwarden Multi-Way 5 30th December 2002 11:36 PM
Page generated in 0.09021 seconds (76.48% PHP - 23.52% MySQL) with 10 queries
