Old 7th February 2006, 03:41 PM   #1
Default My newbie design: 2xlm3886 parallel
At last, "my" first design, based on lot of reading on this forum.
U2,U4: LM3886T
U3,U5: LF412CN
C2 is optional, that's why the switch.
I choose LF412CN because I cant find the AD8620 here.
U1: that's a problem.
I would like to use AD815, but again, I cant find it in Argentina. My choice is NE5534, but also I can use:
OPA128,OPA234,OPA277,
OPA336,OPA2228,OPA2234,
OPA2277,OPA2604,OPA2681
AD620
The power supply will be 24+24 transf, 8xMUR diodes each one with .1uf in parallel, 1ohm R on each line (like CarlosFM's power supply) and some snubbers. Talking about snubbers, where should I put them??
All chips will have 0.1uf + 100uf for (+) and (-), and U1,U3,U5 will have +- 15 regulated power supply (7815 & 7915)
Comments? advices?
everything is welcome!!!!
Old 8th February 2006, 12:59 AM   #2
Ehemm,.... helpppppppppppppppppppppppppppppp
Old 8th February 2006, 01:06 AM   #3
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Why the output stages are inverted???
Are your schematic drawn with Electronic Workbench(or Multisim)???
Old 8th February 2006, 01:10 AM   #4
pinkmouse's Avatar
Your font has confused my mac...
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 8th February 2006, 01:30 AM   #5
What do you mean with inverted?
yes, I'm using multisim. do you know a better program ? tell me that's the only one I have
I'm really sorry, I will try to fix it or post it like a JPG
Old 8th February 2006, 01:35 AM   #6
pinkmouse's Avatar
GIF or PNG are the best formats for schematics. Your PDF should work fine if you use a standard typeface like Times or Helvetica.
Al
Old 8th February 2006, 01:35 AM   #7
Here is the GIF version.
Old 8th February 2006, 02:58 PM   #8
why nobody answers?
I'm looking for your opinion. good or bad. will work? it's a good project? its a waste of time?
thanks!
Old 8th February 2006, 03:13 PM   #9
lineup is offline lineup  Sweden
lineup's Avatar
Default Re: My newbie design: 2xlm3886 parallel
U2,U4: LM3886T
U3,U5: LF412CN
AD620
Comments? advices?
'My newbie design: 2xLM3886 parallel'
Hello, zafira1981
As LM4780 is two LM3886 in one IC,
you can have a look in the LM4780 Datasheet
There you have a schematic using a parallel configuration.
See my attachment.
You can also read notes in LM4780 datasheet
about what to think about when paralleling.
lineup
Old 8th February 2006, 03:30 PM   #10
Default Re: Re: My newbie design: 2xlm3886 parallel
Hello, zafira1981
See my attachment.
Hi!!!! thanks for your answer. LM4780 isnt available in my country. only 3886's
But I can take some ideas from the datasheet and apply them to 2 LM3886.
thanks
Jorge.
PCB design of parallel of two inverted LM3886 with buffer and dc-servo. Roushon Chip Amps 74 11th April 2012 11:17 AM
Visaton FRS 8 M Parallel Notch Filer Design swin1 Full Range 13 22nd October 2009 10:21 AM
mixing series and parallel Xovers in the same design Puggie Multi-Way 0 10th October 2005 09:03 AM
using series and parallel Xovers in the same design, is it ok? Puggie Multi-Way 3 3rd June 2005 05:25 PM
Help! Parallel 2x 3875 per channel design - please advise. loong Chip Amps 23 3rd April 2004 10:08 PM
Page generated in 1.11282 seconds (8.73% PHP - 91.27% MySQL) with 11 queries
