In search of a perfect attenuator
Old 7th March 2006, 06:24 PM   #41
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
In search of a perfect attenuator Send a message via AIM to Peter Daniel
Originally posted by KT
How about buffer unit before the TVC? How does that compare to the buffer before the resistor attenuator?
Does the buffer give some drive and bite to the TVC sound that it was missing?
I tried the TVC with a buffer but I was still getting more resolution "edge" with resistor based attenuator. However, that may depend on particular systems and personal preference. I cannot say that one or the other is definitely better.
To order kits contact me through forum mail.
Old 16th March 2006, 10:32 PM   #42
SamL is offline SamL  New Zealand
According to some of the folks in Headwize, Shunted Linear Pots have varying impedance to the source which wll affect the sound quality.
http://tangentsoft.net/audio/atten.html
Have fun,
Sam
Old 17th March 2006, 12:36 PM   #43
A. J. Gandulfo is offline A. J. Gandulfo  Argentina
Thumbs up ALEPH30 and ATTENUATOR
Dear Peter:
Congratulations for your work.
I purchased from you a DAC, 1 Premium LM3875, 1 Premium LM4780 Kits and from your partner, George a PRE T-1.
Please can you let me know if you still have Aleph30 boards in stock, and what about the selected Mosfets.
Wich is the 22KMF power supply capacitors Brand and type you recomend.
Regarding the Attenuator proyect I am interested to purchase one, can you tell me what do you thimk to offer and wich resistors Brand and type you preffer ?
Giorgio
Old 17th March 2006, 01:32 PM   #44
Hi Georgio,
I will reply later in more detail to your post, however, I could not resist commenting right now on the quote below:
Thanks for an interesting link. The article didn't mention anything about affecting sound quality, it only comments on source's performance, which is not neccessarily the same:
"Another problem with this technique is that a shunted pot presents a varying impedance to the source as you turn the knob. A pot without a shunt resistor presents a constant impedance to the source, so the source's performance doesn't change as you turn the knob."
So, success with implementing such attenuator will depend on the source itself, but with well designed outputs, it shouldn't present major problems. My source has high current drive capability with 6 ohm output resistance.
I'm using series 10k resistor at the amp's input (fixed) so input impedance never goes below that value. I don't need wide range of volume setting for normal listening, and so far, I only needed shunt resistors values between 402R and 3.48K. That varies input resistance between 10402R and 13480R. I don't think it affect any performance.
I would not recommend linear pot for such application: only a switch with discreet resistors.
After saying that, the attenuator board I'm working on, has constant input impedance that does not change through all 130 steps.
Old 17th March 2006, 07:41 PM   #45
Thumbs up ALEPH 30 and ATTENUATOR
Dear Peter,
You answer another post, please read again mine.
Thanks and congratulations again.
Giorgio
Old 17th March 2006, 09:50 PM   #46
Default Re: ALEPH30 and ATTENUATOR
Thanks for appreciating my products
I will have more Aleph30 boards next week, as I ordered new batch. I also have one more set of output mosfets left.
Regarding 22,000uF caps I have some Siemens Sikorel, but those would be quite expensive. Another good brand could be Nichicon Super Through from Percy Audio.
The attenuator still needs programming to be done. The resistors I like here, are nude Vishays from Texas Components in series position, and with GC amps, Caddocks MK132 in shunt position.
Old 17th March 2006, 11:30 PM   #47
XELB is offline XELB  Portugal
Nice work Peter
I think you read people mind, I am just needing something like that
If you want power you must add control
Old 18th March 2006, 08:55 AM   #48
Hi Peter,
Thanks for your replay.
You got me very interested now. Looking forward to the product release.
Is it possible to have 25K resistor at the amp input? This will work better with my not so granty source like tuner and video.
Have fun,
Sam
Old 3rd April 2006, 08:36 PM   #49
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
I to are also interested. Has there been any more progress on this ?
Old 3rd April 2006, 08:48 PM   #50
As mentioned in the other thread, the control board has been already fabriacated and my partner in that project, Veteran, is working on programming.
The input resistance can be set to any value.
In search of a perfect attenuatorHide this!Advertise here!
