In search of a perfect attenuator
Old 22nd May 2010, 05:31 AM   #101
bikerboy is offline bikerboy  United States
Talking Remote volume control
Hi Peter,
I would like to get a set up like this. I use a Lighter Note LDR single ended pre amp now.I would like to try this to drive a balanced set of ldrs and allow me very tight control of the 4 gangs needed and make a balanced remote controlled Lightspeed LDR preamp. I would need switching of 2 balanced inputs and 2 single ended inputs also. If I dont like it I can revert it back to the ladder resistor set up. I need one!
Old 2nd June 2010, 02:15 PM   #102
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
In search of a perfect attenuator Send a message via Yahoo to vdi_nenna
I wish I would have read this before buying the PEC!
I build, therefore I am.
Old 8th September 2010, 05:00 PM   #103
vdi_nenna's Avatar
The PEC actually isn't that bad. Mine tracks well up to 12 O'clock.
Only real problem is it's scratchy when turning up the volume.
It sealed, so not sure why it's making noise.
Is there a break-in period with PECs?
Old 27th March 2011, 04:07 AM   #104
bpetrus is offline bpetrus
Default Relay-based attenuator
Peter and Veteran,
How did the relay-based attenuator end up sounding?
Brad
Old 27th March 2011, 08:14 AM   #105
veteran is offline veteran  Poland
veteran's Avatar
Perfectly for me. This passive volume control is very neutral. There is only one minus - relays are a little noisy when changing the volume
Simple audio solutions
blog.unisonus.com
Old 9th December 2012, 11:05 AM   #106
TANDBERGEREN is offline TANDBERGEREN  Norway
Well, did it all end here?
Is the perfect attenuator found?
Will it ever surface so we can be able to experience its "second to none" facilities?
Sooner or later you end up with TANDBERG
In search of a perfect attenuatorHide this!Advertise here!
