Sound Quality from Snubbers
If you guys want low impedance and capacitance at high frequency, why don't you use a downgrade of caps with lots of them in parallel to reduce the impedance ? :rolleyes:
Because if you want high capacitance at high frequencies big caps don't solve your problem, even if you use a snubber.
It's true that the snubber helps, or the 100nF helps but, it's not the same thing as small caps ;)
We all know that big caps at high frequencies they are rubbish :dead:
