| Chip Amps Amplifiers based on integrated circuits |
What is the best config for a 100 - 150 W for 6 ohms speakers?
2 parallel? bridged? I will use this speakers http://www.yamaha.ca/av/speakers/PDMSeries/NS150.asp thanks |
#2 |
Zzzzz,......
anybody there? ? |
#3 |
Is that looking for 100-150 watt per channel, or total?
I'm still just a little guy but I'd say probably parallel. You can do 100W into 6 ohm with 25V and about 4A. That's enough voltage for the 3886 to handle with ease, but enough current to merit paralleling. If you bridged, the supply voltage could be lower for the same effect but I believe each chip would be driving twice the current. |
#4 | |
For power supply I have 2 transformers that I could use. first: 18-0-18 350 VA (EI) second: 4x 12V 150VA toroidal, 24-12-0-12-24 why 4? because in my country i cant find 24-0-24 toroidal. Maybe for the first trans. I should use bridged, and parallel for the second option. thanks!!! Jorge. |
#5 |
Try searching overture_design_guide14.xls at www.national.com
#6 | |
#7 | |
Bridge or Parallel?
S. Roushon |
#8 |
I would recommend reading BPA-200 app note also(you can find at national's site too).
#9 | |
Thanks!!! I'm looking your thread. |
#10 | |
well I've read your post and was very helpfull. did you build the project? I'm thinking on use your schematics as "base" of my project, if you dont mind. But, with some modifications. per channel: 2xLM3886T 1xLF412 1xAD620 or 1xNE5534 why? because I cant find here variety of opamps. I will start drawing
| Need some help on speaker config | pityocamptes | Car Audio | 11 | 4th October 2007 12:59 AM |
| ISOBARIC 16 ohms load powered by 8 ohms Amp | eddi0 | Subwoofers | 24 | 21st October 2006 03:29 PM |
| Speakers: 8 ohms vs. 16 ohms | KT | Multi-Way | 2 | 14th April 2006 05:06 PM |
| Max supply voltage for LM3886 @ 4 Ohms | madscience | Chip Amps | 8 | 4th October 2005 06:00 PM |
| need help on my config | hacknet | Solid State | 14 | 2nd December 2002 03:43 PM |
| Page generated in 0.13884 seconds (69.95% PHP - 30.05% MySQL) with 10 queries |
