| Chip Amps Amplifiers based on integrated circuits |
I want designed stereo LM4780. The output current of LM4780 is 7A (+3.5A -3.5A).
Trafo 2x22vac 7A (+7A -7A 308VA) is good ?? or big?? |
#2 |
It's just fine.
Regards, Milan |
#3 | |
Thnks Milan !!. Best Regards Greg I'm going to designed!!!!!!!!!!!!!! |
#5 | |
I want say 200VA ? for stereo LM4780 (2x40Wrms)
#6 |
Electrons are yellow and more is better!
When it comes to choosing a transformer it's about the temperature inside. As long as it is under 105 deg C it's sufficient if also voltage drops and other things are under control. Think average power taken out of the transformer.
/Per-Anders (my first name) or P-A as my friends call me |
#7 | |
Can you please elaborate the needed transformer's power rating for this amp if the temperature inside the chassis is 105degC? |
#8 |
2 x 40 watts continuous, then a 100 VA is too small but I said music....
The VA rating is determined of max temperature inside. Higher than 105 deg C the insulation will get damaged. Notice also that the temperature also has to do with mounting and cooling.
#9 |
Can you then please elaborate the needed transformer's power rating for this amp if the temperature inside the chassis is 100degC?
#10 |
Then of course possible output from the transformer will be less.... 100 degs inside
| OPT Trafo | Dynsdale | Tubes / Valves | 10 | 22nd March 2009 06:41 PM |
| Power supply options.. bigger trafo with less caps or medium trafo with heavy caps? | rhythmdiy | Chip Amps | 9 | 23rd October 2007 12:30 AM |
| SE Trafo for PP use | dsavitsk | Tubes / Valves | 15 | 8th August 2007 08:27 PM |
| Of what value is this trafo? | wxn | Parts | 7 | 13th June 2005 12:08 PM |
| Trafo to buy for PWM amp | partyjups | Solid State | 6 | 19th December 2001 10:32 PM |
| Page generated in 0.10403 seconds (75.57% PHP - 24.43% MySQL) with 10 queries |
