Old 5th February 2006, 06:16 PM   #1
Default Distortion on p2p LM3875 - probably my fault :D
Hello
As a little project and to try to make a case I have knocked up a p2p (mostly) LM3875 but... It sounds really distorted.
I have used a chipamp rectifier board and added some additional capacitors and stuff - the power supply but checks out OK and all that.
I have changed 2 of the resistor values - the one which goes from pin 3 to 8 is 10K instead of 22K and the one that goes from pin 8 to ground is 330 - IIRC, this should give me a bit less gain as the ratio is 30 instead of 32 but should still work properly. The input resistor is 1K. I have used different diodes >> http://uk.farnell.com/jsp/endecaSear...U=250697&N=401
Anyway... The sound is really distorted - it's like the input levels are way too high.
Is this problem likely caused by the substitution of the resistors?
The resistors are all in the correct places etc and nothing is shorting out. Both channels are exactly the same.
Any ideas appreciated
Old 5th February 2006, 07:45 PM   #2
Nordic is offline Nordic  South Africa
Nordic's Avatar
why not take your circuit and draw what you see in a circuit diagram for us.
Old 5th February 2006, 08:21 PM   #3
OK, good plan!
Here is the diagram.
Thank you.
Old 5th February 2006, 11:24 PM   #4
Vikash is offline Vikash  United Kingdom
diyAudio Moderator Emeritus
Vikash's Avatar
Try adding a resistor to ground on the input and/or reducing the input resistor R1: http://www.purplestorm.co.uk/vikash/audio/gainclone02/
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.)
Old 6th February 2006, 12:19 AM   #5
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
The input RF filter is missing.
Old 6th February 2006, 01:22 AM   #6
Tube_Dude's Avatar
Default Re: Distortion on p2p LM3875 - probably my fault :D
Have you used a pot at the input?...if not , you need to put a resistor from pin 7 to ground to bias the non inverting input.
Jorge
Old 6th February 2006, 05:32 AM   #7
Nordic's Avatar
it is also advisable to add a small (2.2. - 4.7uf) poly cap in the input path to protect against high DC offsets on the output, that can fry your speakers.
Here is Nuuks diagrame
Some notes, he used 2 resistors in paralel on the feedback to get to a bit over 200k, also that input cap is 4.7uf not 47...
This is an inverted design, so its not going to like a pot too much
that 56k resistor can be soldered directly between live and ground on the input RCA, keep wires from this ground to the ground star thinner than the rest of your earth wires...
Old 6th February 2006, 06:30 AM   #8
Thank you everyone
I'll add the resistor to ground and change the input resistor for a lower value.
I did use pots but I think I wired them in wrong (I couldn't find any diagrams of how to connect them) so removed them - they didn't do anything when I turned them
I thought I was copying the chipamp design with a 1K input resistor and nothing going to ground but I guess I got it wrong..
DC offset is 0.3mV and 0.4mV with an 8 ohm load but adding blocking caps is a good idea just in case as I prefer my speakers unfried.
Thanks again
I really should read a book about all this stuff...
Old 6th February 2006, 06:41 AM   #9
Nordic's Avatar
Look, I think your circuit should work, and its more than likely a dry solder joint... would especilay look at connections to the feedback resistor, also just double check your resistors, I once accidentaly took a 1k resistor instead of a 10k on the input and ended with a gain of about 200, which sounded just horrible.
Old 6th February 2006, 11:24 AM   #10
Igla is offline Igla  Slovenia
I would say that the input is overloaded.
What do you have in front of your GC? CD player, computer soundcard, a preamp ?
Pre amp fault Addolff Parts 4 6th January 2008 01:55 PM
cd6000 fault goodlife Digital Source 11 28th April 2006 06:31 PM
Buffer Fault pete.a Chip Amps 17 8th September 2004 08:10 PM
Non Linear Distortion testing - Harmonic Distortion JMB Multi-Way 0 20th July 2004 02:54 PM
LM3875 and Distortion newbie1 Chip Amps 16 21st February 2004 02:29 AM
Page generated in 0.10780 seconds (72.36% PHP - 27.64% MySQL) with 11 queries
