| Chip Amps Amplifiers based on integrated circuits |
What is the maximum voltage for this chip???
What output effect would this give MadFinn |
#2 |
LM3886 Supply Max 84VDC or +/- 42VDC
68W into 4ohms at Vcc=+/- 28V 38W into 8ohms at Vcc=+/- 28V 50W into 8ohms at Vcc=+/- 35V over 35V+/- thermal and spik protection become an issue due to package dissipation(125W max). |
#3 |
The data sheet says supply range from 20 to 94 volt, so ±10v to ±47v.
Also according to the data sheet, ±10v gives very little output power (~5W), where ±47 is off the chart. Well, it says 94V on the front page... 84V as the limit everywhere else in the sheet. |
#4 |
#5 |
94 volt= Absolute maximum..
SivanandBalan |
#6 |
The absolute maximum rating for an LM3886 with an input signal is 84V. You can find this info on page 3. Most amps aren't very useful without an input signal...
Absolute maximum ratings are just that. If you exceed these values you will probably fry the part (and maybe your speakers, too). Also check note 2 at the bottom of page 4. Now we will hear from a half dozen guys who run the power supplies at 100V with no problems... yet. I_F |
#7 |
Ok thanx for your answers
Now to next question in this subject: If i want sat about +- 40-45 volts What voltage does the transormer have then I have understod that +-30 volts gives a hagher voltage after the diods right ??? what i the formula to calculate this???? |
#8 |
Roughly AC voltage times the square root of 2.
#9 | |
Electrons are yellow and more is better!
/Per-Anders (my first name) or P-A as my friends call me |
#10 |
Two seconds on google yielded this:
http://my.integritynet.com.au/purdic/power1.html and this: http://sound.westhost.com/power-supp...y-requirements I_F |
| My First LM3886 GC | samsagaz | Chip Amps | 49 | 29th June 2008 07:55 PM |
| Psu Lm3886 | Mayday | Chip Amps | 29 | 29th April 2007 06:10 PM |
| Lm3886 Bpa | Tombson | Chip Amps | 99 | 21st August 2006 12:04 PM |
| Are two separate lm3886 = 2*lm3886 in parallel or bridge mode | rs1026 | Chip Amps | 11 | 21st October 2004 10:24 AM |
| Page generated in 0.09170 seconds (81.75% PHP - 18.25% MySQL) with 10 queries |
