Old 29th January 2006, 10:11 PM   #1
hotscot is offline hotscot  Scotland
Default Speakers for Gainclone
Newbie considering building a Gainclone in order to learn something about DIY amps.
I keep seeing comments concerning the types of speakers you can drive with them. The sensitivity etc..
Can anyone please give examples of the types of speakers they use with a Gainclone?
For example currently I use KEF iQ7 and I wonder if they'd work together.
http://www.kef.com/qseries/products.htm
Alan
Old 30th January 2006, 01:30 AM   #2
I think what is important is 4ohm or 8ohm and the voltage on the transformer secondaries...
Also would 30-50wRMS be enough for those speakers? You might want to look into about how much the amplifier will be putting out with X transformer and how much you need.
Old 30th January 2006, 01:49 AM   #3
edjosh23's Avatar
I think the best way, is just to build the gainclone and find out. The specs say that those don't need much power, they are 90db effeciencent. The website also says the they are normally 8 ohms, but go down to 3.2 (kinda like my B&Ws). My torroid is perhaps a little high for my speakers, and I want to step it down so I can use 4ohm speakers.
By the way, I really like those speakers.
I'm trying to attach a chart, lets see if it works.
Josh
Old 30th January 2006, 12:49 PM   #4
Mick_F is offline Mick_F  Germany
Use the LM3886 if you want to drive 4 ohm speakers.
Mick
No statement here.
Old 31st January 2006, 03:31 AM   #5
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Hi hotscot,KEF's Q series need good driving capability amp to partner with,so make sure your gainclone is feed with beefy power supply.
Old 31st January 2006, 03:50 AM   #6
Thanks Leo.
Does that translate to a more powerful transformer?
I'm new to this and it's not clear to me the differences between transformers. Is it related to the current capabilities?
I'll do some research tomorrow.
Old 2nd February 2006, 05:05 AM   #7
Arx is offline Arx  Canada
Have a look at the datasheets for the chips. they'll suggest what you should be aiming for voltage wise. (Keep in mind the rectified DC Volts will be a fair bit higher than the the rated V AC)
As far as power goes, I would think a couple hundred VA would do.
There's really not much to "beef" up. nominally 8 ohms isn't really a big deal. If it dips that low, though, you might want to lean a bit on the low side with the supply voltage.
My GainClone is Blowing up Speakers Arunkumar14_th Chip Amps 17 28th January 2009 02:19 PM
100V Speakers and the GainClone Amp. McKiltie Everything Else 7 9th September 2007 09:24 PM
Gainclone speakers steven344 Chip Amps 9 22nd November 2005 03:47 PM
Efficient DIY speakers for gainclone under or around $300 US? TheDriver41 Multi-Way 25 25th September 2004 04:18 AM
HT speakers to pair with a gainclone? AJ Bertelson Chip Amps 7 3rd January 2004 11:11 AM
Page generated in 0.09628 seconds (68.64% PHP - 31.36% MySQL) with 11 queries
