LM3875 BrianGT kit not working
Old 28th January 2006, 01:26 PM   #1
waltson is offline waltson  Finland
Default LM3875 BrianGT kit not working
Hi all.
Suddenly the other channel of my gainclone stopped working.
When I opened the case, I noticed that the V- wire from the power supply was loose. I reattached it and it still doesn't work. Is it possible, that the loose wire caused the chip to fry? What could I do to find out the reason for the malfunctioning?
Thanks.
Old 28th January 2006, 01:32 PM   #2
Tekko is offline Tekko
Banned
Your lucky that the ic dident fry your speaker when the -Ve wire loosened.
Old 28th January 2006, 05:58 PM   #3
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
I have never destroyed a LM3875 or 3886 so I don't know possible ways of destroying. You can try at least to check input bias currents, voltages at the inputs and the output. Maybe also the current consumption in both supply voltages.
Be prepared for a fried chip.
/Per-Anders (my first name) or P-A as my friends call me
Group buy: SSR03 Super Regulator Power Supply. Sign up HERE 53 pcb's in interest so far.
Old 28th January 2006, 06:03 PM   #4
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
LM3875 BrianGT kit not working Send a message via AIM to Peter Daniel
The chip won't break, or damage the speakers, when one of the supply rails is missing.
Check the PS first, if it's producing proper voltages.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 28th January 2006, 06:05 PM   #5
Banned
I tried to destroy two parallel lm3875 on purpose once, when nothing worked after hours of trying, i had only one thing left to try, shorting the outputs and max the volume. That finally did it.
Old 28th January 2006, 06:07 PM   #6
Without signal maxed, shorting the outputs won't break the chip either (at least in half an hour or so).
www.audiosector.com
Old 28th January 2006, 06:27 PM   #7
Banned
If these ics breaks just like that its factory error. Tsese ICs wont break unless u really try to break them like overvolt them or shorting the outputs with volyme at max.
Old 28th January 2006, 06:39 PM   #8
john65b is offline john65b  United States
john65b's Avatar
Default My Bad Experience...
I broke the Number One Rule of soldering the other night, I was rushing to finish soldering up the last of my LM3886 amp while EXTREMELY TIRED.
The amp is configured as a single Toroidal Tranny/rectifier/cap bank. I finished and powered her up and saw a little puff of smoke out of my Left Channel LM3886 (yes, they are heat sinked). I then put her away for the night and went to sleep. After work the next day I looked her over and I completely forgot to attach both amps to power GROUND.
I replaced the smoked amp board with a new one (the other channel seemed fine), connected the Power GROUNDS to both amp boards and all was good with the amp.
Now the smoked chip. I looked at under a loupe and the #6 pin is charred - and #6 pin is No Connection. I am perplexed at what I could have done. It is next to the #7 pin which is GROUND. Looked over the PCB and nothing else seems amiss.
Any thoughts? And beside reconnecting the board, is there any way I can check to see if the LM3886 chip is really fried with a MM to the chip pinouts?)
I can get a new chip for $3.50 and replace it, but these chips are pretty indestructable, aren't they? And I hate DESOLDERING !
Old 28th January 2006, 07:31 PM   #9
Banned
If a ic fries, cut the legs off close to the ic and then just desolder them one as a time.
Old 28th January 2006, 09:00 PM   #10
Nordic is offline Nordic  South Africa
Nordic's Avatar
You wanna fry one quick? leave a solder trace from one of the voltage rails to the output, bang!!!!!!!!!!!!
LM3875 BrianGT kit not workingHide this!Advertise here!
FA: BrianGT LM3875 amp in case fireman Swap Meet 1 4th September 2006 06:40 PM
P3A and BrianGT's LM3875 nina Solid State 5 19th March 2006 02:57 PM
Finished BrianGT LM3875 kit MtBiker Chip Amps 16 10th February 2005 07:26 PM
WTB: BrianGT LM3875 boards guzzler Swap Meet 1 10th December 2004 11:34 PM
Copyright ©1999-2017 diyAudio
