Old 13th March 2006, 10:01 PM   #31
Ok, I set the meter to the lowest range which is 10m DCA. Is this low enough? I still don't get any readings. Perpaps I should just go and get a digital one. This is really frustrating. I know it's some simple, but when you don't have exprience with it.... it sucks.
Chev
Old 13th March 2006, 11:25 PM   #32
OK, I've got an update!
I was able to get a digital meter and was able to get a reading. The left side was 1.6 and the right .6. Now this seems odd. Shouldn't both be the same? BTW I set the meter at 200m to get these readings. Does this sound Ok?
Chevy
Old 13th March 2006, 11:43 PM   #33
Arx is offline Arx  Canada
well, if those are milliamps dc, that sounds quite good.
The two sides won't neccessarily be the same. It can vary with either small differences in the chips, or other supporting components.
Either way, you shouldn't hear any difference at those levels.
I'd still hook it up to some lousy speakers you don't care about first. Always a good idea just incase you missed something and it smokes them.
-Nick
Old 13th March 2006, 11:52 PM   #34
xplod1236's Avatar
Send a message via AIM to xplod1236
the meter should be set on millivolts, not milliamps
Old 14th March 2006, 02:27 AM   #35
Yes to was set to millivolts.
My father-in-law has a bad set of speakers he said I could use. So if I blow them he doesn't care
Chevy
Old 14th March 2006, 03:34 AM   #36
Nordic is offline Nordic  South Africa
Nordic's Avatar
Sounds just fine... forget about getting them even without servos etc... Well now you know if your output DC can't be measured on yourbig multimeter, it is negligible....
Old 14th March 2006, 06:33 AM   #37
Oops.. Yeah, my bad.
(Newbie) CSS Question bibster Tubes / Valves 8 24th January 2007 10:22 PM
newbie with input tran. question and wiring question imo Solid State 0 18th January 2006 10:10 PM
newbie question kambrian Multi-Way 5 28th December 2003 10:16 PM
newbie post, but hopefully not a newbie question wiredcur Solid State 3 24th August 2002 10:49 PM
Page generated in 0.15299 seconds (53.68% PHP - 46.32% MySQL) with 10 queries
