Old 27th January 2006, 07:11 PM   #1
Default LM4780 ESL Amp
Is there a way to create a "chokepopint" so that the amp only sees a max of "2" ohm impedance at most?
What is the negative to this?
Also, What is the max transformer that the LM4780 can handle?
Thanks,
Dominick
A real amateur enthusiast!
Old 27th January 2006, 11:23 PM   #2
I_Forgot's Avatar
Sure, put a 2 Ohm resistor in parallel with the speaker.
But.... why?
The "negative" is that the impedance will go below 2 Ohms, and few amps handle that without getting hot or even commiting thermal suicide.
I_F
Old 27th January 2006, 11:27 PM   #3
pinkmouse's Avatar
Seconded, why?
As for the traffo, I'm running on a 30-0-30, about as high as you can go. This needs good heatsinking.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 28th January 2006, 12:03 AM   #4
Well,
I guess i posed my question wrong.
What I am trying to do is create an ohm minimum chokepoint.
Something that will PREVENT the Impedance load from going Below 2 ohms.
I havent settled on this value yet, but I am just wondering if there is a way to do it.
WHY?????
The Martin Logan speakers the amp will be driving can go down to .1 ohm at high frequencies.
Thanks,
Dominick
Old 28th January 2006, 12:05 AM   #5
pinkmouse,
What would the VA rating be with the 30-0-30. Could I push it to 500 VA....or father as long as I remain at 30-0-30???
Old 28th January 2006, 12:56 AM   #6
mwmkravchenko's Avatar
Default Transformer !
A proper transformer will keep the impedance at an acceptable level. The transformer used for stepping up the voltage off of the amp that is.
MArk
Mark
Old 28th January 2006, 01:02 AM   #7
Default ESL's and the lm4780
Back down the supply voltage to +/- 22VDC, that will give you a little cushion for resistive dissipation in the amp. If you are useing the lm4780 in parellel, and I imagine you are, increase the output resistors to 1ohm 5W 1% non- inductive resistors, the amp will double its output current and stay within its dissipation limits, use a zobel of 2.7 3W and 1NF, and a 1MH coil that can dissipate peak current of the amp in rarellel with a 8ohm 3W resistor to unload capacitance. You wont drive them hard but the amps will work. PS lots of heat sink........
Old 28th January 2006, 02:20 AM   #8
tiltedhalo,
What an answer...thanks a ton.
Everyone else has suggested maxing out the transformer values..I wonder why?
Your right, I am going to be running 2 paralled LM4780 chips per channel.
Here is where you lost me though...
"and a 1MH coil that can dissipate peak current of the amp in rarellel with a 8ohm 3W resistor to unload capacitance."
I will do everything you mentioned, but what is a 1MH coil and where on the board am I placing the 8ohm 3w resister????
Also, just so you know, I upgraded the 50V 1500uf caps to the Nichion 63V 4700uf caps thanks to Peter at audiosector.com.
Thanks for the great response,
Dominick
Old 28th January 2006, 04:33 AM   #9
Default LM4780 ESL amp
This might help, and if you need more voltage to load you could bridge two parellel chips together with a DRV134 Click the image to open in full size.
Old 28th January 2006, 04:49 AM   #10
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Default Re: LM4780 ESL Amp
Bridging is not recommended here, as the speakers impedance is too low.
2 x 22V transformer should be fine, and that's what I'm using with all my amps (though those are mostly LM3875)
You could still use higher voltage (especially if chips are run in parallel), but because of your "difficult " speakers it's probably better to keep it low.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
sonic differences between inverting/non-inverting LM4780 VS both non-inverting LM4780 jarthel Chip Amps 5 19th July 2007 12:37 PM
LM4780 from who? jarre Chip Amps 6 10th August 2006 07:04 AM
lm4780 p/s j9184p Power Supplies 4 28th June 2006 04:18 PM
anybody tried a LM4780? travis Chip Amps 162 23rd March 2005 08:14 PM
lm4780 odysseybmx414 Chip Amps 2 22nd February 2005 06:13 AM
Page generated in 0.12622 seconds (74.52% PHP - 25.48% MySQL) with 10 queries
