Old 23rd January 2006, 09:10 AM   #1
Wynand is offline Wynand  South Africa
Wynand's Avatar
Default Voltage Regulators query
If I want to use the LM317/337 to power a preamp, basically just one opamp, would I need a heatsink?
The input V will be max 35Vdc
Old 23rd January 2006, 09:16 AM   #2
pinkmouse's Avatar
Didn't you ask this question a while back, or am I going mad in my old age?
Dissipated power is a product of the voltage dropped and the current used. For that much voltage drop, even at low current, I would heatsink the regs. Better safe than sorry.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 23rd January 2006, 09:21 AM   #3
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
IOW, if the input is 35V, and the output is 15V, dropped V is 20V. With a load of say 25mA (probably less) P = 20 x 25 mW = half a watt. Maybe just a small sink would be wise, as Pinkmouse said.
Jan Didden
/Another new issue: Linear Audio Volume 3!
Old 23rd January 2006, 09:27 AM   #4
Wynand's Avatar
If I've asked this question before I apologize. I can't remember it though (and I don't even have old age to blame
Thanks for the explanations !!!
Old 23rd January 2006, 09:36 AM   #5
pinkmouse's Avatar
No problem Wynand, I'm sure I've done the same thing before!
Jan's post gives you the numbers, though I was rather hoping you'd do the maths and get a proper feel for it, then you can use it again in the future. I've found that working out simple questions like this helps a lot to get a feel for a circuit and leads to greater understanding in the long term, and as a relative newbie, I certainly need all the understanding I can get.
Al
Old 23rd January 2006, 10:56 AM   #6
janneman's Avatar
Point taken, Al
Jan Didden
Pre amp voltage regulators help. AMV8 Solid State 19 6th April 2007 09:30 PM
voltage regulators odysseybmx414 Chip Amps 23 2nd January 2006 08:35 PM
Paralleling voltage regulators? m.parigi Solid State 4 14th April 2004 04:01 PM
voltage regulators GAK Tubes / Valves 12 25th January 2004 04:34 PM
voltage regulators NAP 160 Digital Source 7 11th August 2002 09:14 PM
Page generated in 0.09118 seconds (78.21% PHP - 21.79% MySQL) with 10 queries
