| Chip Amps Amplifiers based on integrated circuits |
Hi
I am planing on puting together some 3886 briged\parallel circuit BPA200 from national for a subwoofer amp and this will drive a 4ohm sub. My problem is that i have a transformer 500VA 25-0-25 and with the psu i will have +/-38V.I know this is to much. What can i do to reduce it to 28-30v as National recommends??? Thanks |
#2 |
Unwind some secondary windings of your transformer.
#3 |
(25 * 1.414) - (2*0.7) = 34V
the 0.7v drops are due to the diode voltage drops. Those numbers are actually very accurate, as I run a pair of 625VA 25-0-25 traffos that put out ~34V unloaded on each rail after rectification |
#4 |
I know this is a solution, searhing the forum i read it somewhere but i haven't done this befor and i'm afraid i will damage my toroidal.Is it so easy?About how many windings must i cut off?
#5 | |
1.2*25=30V |
#6 |
HI
Sorry about the 38V, it is 34v.I will tray it with this voltage and see it, if i manage to make it work. I build the bpa200 basic circuit p2p exactly as it is in AN-1192 no servos and with lf412acn.The resistors are 0,1% as national recommends. I connected a cdplayer and a 8ohm old speaker i have for the first tests and nothing is going out from the speaker. Dead silent. I mesure the supply voltage on each IC and all is ok I mesure the dc offset and i have 3mv with a 8ohm load! I used some pc speakers to hear if the signal is ok at the lf412 output(because i dont have a oscilloscope) and it is. I have overchecked all the signal paths, supply rails, grounds, all ok The only thing i dont know if it is ok and haw to check is the lm3886's without ansoldering them. Is there a way to check them??? Can someone experienced please help me??? Thanks |
#7 |
What is the value of the resistor on the mute pin?
Have you tried each 3886 separately to see if they work? |
#8 |
I dont have any resistor there. Must i put a resistor at the mute pin???
#9 |
Yes each 3886 need a resistor from pin 8 to pin 4
#10 |
Hah
). So your amp is mute , and you will never hear anything from it.resistor is usally selected ~40 kOhm and connected from -Vs to Mute pin. There is formula how to calculate Resistor's value exactly in datasheet. |
| Bpa200 Opa549 Sub Amp | Gcollier | Chip Amps | 8 | 2nd October 2006 11:58 PM |
| Bpa200 | enter | Chip Amps | 2 | 3rd January 2006 08:16 PM |
| BPA200 PCB Layout | nterikun | Chip Amps | 12 | 13th September 2005 12:51 PM |
| My BPA200 PCB | Dxvideo | Chip Amps | 14 | 11th December 2003 07:25 AM |
| Page generated in 0.28033 seconds (33.61% PHP - 66.39% MySQL) with 11 queries |
