Old 22nd January 2006, 03:45 PM   #1
tangen is offline tangen  Norway
Default gainclone as an amp for bassguitar
My son and I built a gainclone some time ago, based on Peter Daniels boards. The other day he asked me if he could use this one in a bridged version as an amp for his bassguitar. He planned to replace the RCA input and speaker connections (output) with two jacks (in and out respectively). He will use the volume potmeter we already installed as a "passive preamp" with the boards.
Will this be ok? Anyone with experience from such a project?
Best wishes
Jan Ove
Old 22nd January 2006, 04:09 PM   #2
I_Forgot's Avatar
Guitar pick-ups don't produce much voltage out. You'll probably need to add a gain stage. An opamp wired for a voltage gain of 10 or 20 should do.
Guitar guys like to have tone and distortion controls. There is a pretty easy to build device here: Practiceman
You can make all sorts of parts substitutions. In this case, just replace the LM386 output stage with your power amp stage. Make sure the power amp stage has a hefty power supply and a good heatsink.
I_F
Old 23rd January 2006, 06:26 AM   #3
I would say if using a lm386 based device do something even easier like the littlegem off from runoffgroove.com. On that same note, I don't think thats a good idea. I simple booster would do the trick, like the LBP-1 on tonepad.com and generalguitargadgets.com I myself am building a lm3886 based guitar amp and plan on using a LPB-1 into 3 band fender style passive tone stack and then that into the power amp. For some good stuff, like the schematic for the 3 band tone stack, feel free to check out diystompboxes.com and go to the forum.
Life is what you make it.
http://www.ssguitar.com
Old 23rd January 2006, 02:29 PM   #4
Default Thanks
Thank you very much for your suggestions. I will look into them more closely. They seem promising.
best wishes
jan ove
Gainclone Help! nelsondog Chip Amps 8 22nd March 2007 04:38 AM
Bassguitar for my band.. v-bro Instruments and Amps 17 23rd December 2006 01:44 AM
Freebird + Gainclone = "integrated" gainclone? bikehorn Chip Amps 9 5th January 2006 03:07 PM
JLH v Gainclone? Jezz-the-Fezz Solid State 5 12th December 2005 12:08 PM
Big gainclone steven344 Chip Amps 10 23rd November 2005 07:58 PM
Page generated in 0.07023 seconds (73.13% PHP - 26.87% MySQL) with 10 queries
