Old 21st January 2006, 03:51 PM   #1
Buhl is offline Buhl  Denmark
Buhl's Avatar
Default Problems with DC offset
I have build a PA 100 - more or less as shown in the 1192 app note - but I have serious problems with DC offset. I measure 0.17 volts on two of the chips, and 1.18 and 11.9 volts on the two others !!
I am not using matched resistors or anything as mentioned in the app note, and the amp is DC coupled. I am using the schematic on the madaboutsound site.
Does anybody have any clou what can be giving me this huge offset - I dont find any errors in my implementation.
Cheers !
Buhl
"Calculations? We don't need no stinkin calculations! We just make them really big!" Quote: Nelson Pass
Old 21st January 2006, 04:16 PM   #2
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Hi!
There are many here that would be able to give you an advice, but who are not familiar with this particular amp (out of probably several 1000 floating around in internet space). It would be helpfull (and also considerd courteous) to post a schematic.
Jan Didden
Old 21st January 2006, 04:29 PM   #3
Buhl's Avatar
Hello Jan
Thnx for the hint - should have thougth of it, as it is obvious that people cant help one if they dont know what to help with.
Here goes the schematic:
Thanks !
Buhl
Old 21st January 2006, 04:48 PM   #4
pinkmouse's Avatar
Default Re: Problems with DC offset
Originally posted by Buhl
...I am not using matched resistors or anything as mentioned in the app note...
That is most likely your problem. Try following the instructions and see if that sorts out the problem.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 21st January 2006, 04:52 PM   #5
Buhl's Avatar
Ok, thank you pink mouse - I will try, but really, almost 12 volts of offset due to unmatched resistors ??
How do I match them - I mean, better then my ohm-meter, can I apply some sort of voltage, and then measure the voltage drop ?
Cheers !
Buhl
Old 21st January 2006, 05:05 PM   #6
pinkmouse's Avatar
Eek,I missed the decimal point on the 11.9V.!
2V or so is quite possibly due to component mismatch, but the 12V suggests a dead chip or wiring error. For sensitive matching of components, a Wheatstone Bridge is the way to go, quite simply made, and google will give you all the info you need rather than going into lots of detail here.
Al
Old 21st January 2006, 05:09 PM   #7
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Do you measure offset with source connected or disconnected?
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 21st January 2006, 05:12 PM   #8
Buhl's Avatar
Hi peter
I measured without source.
I have found a dealer near me who sells 0.1 % resistors, so I guess this is the way to go. The two "crazy" offset values must be an error though..... i will go through the whole circuit to nigth.....
Thanks for helping !
Hans
Old 21st January 2006, 05:14 PM   #9
Which chips are you using?
www.audiosector.com
Old 21st January 2006, 05:17 PM   #10
pinkmouse's Avatar
Thanks for pointing out the first thing I should have thought of Peter!
Al
Offset problems, again sangram Chip Amps 21 12th January 2006 03:08 PM
Gainclone with DC-offset problems seve Chip Amps 11 29th May 2004 12:01 AM
DC offset problems with leach amp wrl Solid State 62 3rd March 2004 01:28 AM
gainclone problems (dc offset, no sound) damitamit Chip Amps 3 6th September 2003 06:24 AM
Page generated in 0.09809 seconds (81.98% PHP - 18.02% MySQL) with 11 queries
