Old 19th January 2006, 05:43 PM   #1
Default 5-6 channel GC HT
After looking at this thread, I was wondering if there is a AC3, DTS, Dolby, MP3,ect.. Decoding chip/project out there to intigrate into this. I've seen toslink-analog projects, so it would be nice if I could have all of this in one. I did a search and it didn't look as if a decode chip was out there at the time, has this changed? Any info would be great, or even a simple yes or no.
Thank you
Steve
Old 19th January 2006, 06:19 PM   #2
OK, couldn't find the EDIT button, so I guess I'll reply.
Searching Google: DTS decoding chip
also didn't help. anymore ideas, or is this a proprietary design that can only be licenced by consumer product manufacturers?
EDIT:
how about something like This
or this
Old 19th January 2006, 06:44 PM   #3
leadbelly's Avatar
Your answer is no, there is currently no DIY HT decoder out there. Some searching on the forum might have helped you find that out. There are projects in progress, maybe something polished will come out, maybe not.
There are DIY techniques to get multiple speaker outputs, but all are analog domain, stereo source. The simplest is http://sound.westhost.com/project18.htm
You can add on circuits to embellish the effect, such as a "wide" function on the main front pair, an LF rolloff on the center channel, and preferably a better subwoofer output filter.
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 19th January 2006, 06:50 PM   #4
Thanks for the answer...
..., and i did search under DTS and DTS decode... Like i said, I got the picture that a chip wasn't out at the time of the post and wondered if anything had changed.
Old 19th January 2006, 06:58 PM   #5
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
Yep, the algorithms are integrated into audio DSP's sold by analog device and others. MOQ for these chips are usually 1000 pcs. as far as I know. The royalty to Dolby/DTS is a part of the price for the chip.
/U.
Old 20th January 2006, 02:49 AM   #6
Send a message via AIM to Spasticteapot
Your best bet is to use a dedicated PC with a 5.1 soundcard. The Soundblaster Audigy line is a good way to go.
Old 20th January 2006, 03:27 AM   #7
I have an Audigy, I guess I'll use that. The reason I was wondering is so I could use the Toslink output and bypass possable noise issues in the PC, and also to be able to use the digital output of my current DVD player.
Thanks for the info.
Old 20th January 2006, 04:36 AM   #8
dr f is offline dr f  Australia
Could you buy a cheap HT amp ( hyundai or something) and then bypass the amps so you are only using the decoder and possible the DAC's?
Just a thought
Old 20th January 2006, 04:47 AM   #9
Nordic is offline Nordic  South Africa
Nordic's Avatar
You could look at one of these, similar performance to PC card based broducts, I would asume without the noise A PC injects...
http://www.creative.com/products/pro...6&product=9468
Old 20th January 2006, 12:54 PM   #10
Thanks for the sugestion, I'll have to search "DDTS-100" on the forums/google and see what others have done. This looks promising as a stand alone unit, not requiring the PC.
Creating 5.1 Multi Channel sound from 2 channel jenkrich Everything Else 5 1st September 2009 07:29 AM
4 channel conversion to mono 1 channel iUSERTLO72p Car Audio 24 25th October 2007 05:07 PM
HELP!: Channel volume very very low, other channel fine. harrisni Solid State 2 20th September 2006 11:10 AM
My 4 channel car Amp distorting on 1 channel (large pics) MikeHunt79 Car Audio 9 3rd September 2003 06:41 AM
Help quick! 4 Channel > 2 Channel? zmoz Car Audio 3 5th July 2003 08:48 PM
Page generated in 0.09337 seconds (81.68% PHP - 18.32% MySQL) with 10 queries
