| Chip Amps Amplifiers based on integrated circuits |
Hello,
I haven't been around here lately, have been pretty busy and haven't had a chance to work on any electronics. Anyway, I'm about to start on my best project to date - a 4xLM3886 (2 per channel) bridged stereo amplifier. I've already got the case built, and the transformer, and am just about to start building the amp. My plan is to use a 26-0-26 350-400VA transformer that supplies roughly +/-35VDC. The amplifier will use 4 lm3886's in single ended mode, but bridged into 2 channels using a drv134. That means there is a control board with 2 DRV134. I also have an OPA134 opamp for the sub crossover. I'm planning on running two 8-ohm in-wall speakers with this (can't remember brand off the top of my head). They're currently powered by my Stereo LM3875 amplifier, but it just doesn't have enough power and is showing clear signs of stress, such as odd distortion sounds and a LOT of heat dissipation. Does my plan sound like it will work? if so, I'll be making the PCBs tomorrow! |
#2 |
Power Supply voltage is a little high, If you are cutting youre present amp into thermal and spik protection it will be worse in a bridge config
when the chips are bridged they will see half the individual load so if you are driving 8 ohm speakers each amp will see 4 ohms instead of 8 effectivly doubling your power dissipation. To use a bridge config I would drop the supply to about +/- 22V DC should get you about a 100w or so, Or try a parellel solution or a bridge parellel one.
| My Bridged LM3886 | robertj88 | Chip Amps | 12 | 31st October 2010 03:47 PM |
| Bridged LM3886 psu. | kanifee | Chip Amps | 18 | 4th September 2008 01:57 PM |
| Bridged LM3886 (again ?) | Puffin | Chip Amps | 24 | 14th February 2008 08:10 AM |
| Bridged lm3886 suggestions Please | Scott_drake | Chip Amps | 55 | 16th August 2007 10:06 AM |
| Looking for a PCB for bridged LM3886 | zafira1981 | Chip Amps | 1 | 29th March 2006 03:39 AM |
| Page generated in 0.07731 seconds (73.01% PHP - 26.99% MySQL) with 10 queries |
