Old 15th January 2006, 02:21 AM   #1
Default Adding a power button
Hi all,
I'm new to gainclone and I'm waiting for delivery of my LM3886 kit and transformer. I went to my local electronics store to pick up some items and I wanted get a power button, but I'm not sure what amp to get. The fellow at the store asked me if I wanted a 2 amp, 3 amp or 10 amp switch. What do I need to get?
Chevy
Old 15th January 2006, 03:09 AM   #2
neutron7's Avatar
get the highest rated one that will look ok. although the amp itself may not normally draw much current, when you first switch it on there is "inrush" current which can be a lot more than what it actually uses.
even a 10a switch can be very small anyways.
Old 15th January 2006, 05:31 AM   #3
Nordic is offline Nordic  South Africa
Nordic's Avatar
Each of those chips can command about 11A
Hope you got a double pole switch...
Old 15th January 2006, 05:14 PM   #4
Actually I didn't. It's a single pole. What want is a switch or button to turn power on or off. Can you recommend what I should get and maybe where to purchase it.
Thanks,
Chevy
Ok, I did some searching and I've found what I want. Please tell if THESE is going to have a high enough amps for the LM 3886 chips. I'm looking at the RA and RC series of Rocker switches.
Old 15th January 2006, 06:10 PM   #5
Bazukaz is offline Bazukaz  Lithuania
Send a message via ICQ to Bazukaz
I have found that 6A switches usually break up in a year or so, due to large surge currents when toroid transformer is turned on.
You can try using a soft-on circuit.They are sometimes sold in electronic supply shops.
Old 15th January 2006, 07:19 PM   #6
neutron7's Avatar
those RC ones will do nicely.
Old 15th January 2006, 07:48 PM   #7
Thanks alot neutron7! Now hopefully I can find one locally.
Chevy
cyrus one - on/off power button viva14 Solid State 3 29th March 2007 06:16 PM
Tent Clock switched on by power button D.A.R.R.Y.L. Digital Source 1 18th January 2006 08:19 PM
Need help finding push button power switch to fit my amp Ken C Solid State 4 12th July 2004 11:42 PM
touch button power switch circuit vossie Pass Labs 17 23rd September 2003 06:31 AM
cassette players power button broken debnova Parts 0 27th October 2002 12:59 AM
Page generated in 0.10997 seconds (70.58% PHP - 29.42% MySQL) with 10 queries
