Old 21st May 2010, 05:44 PM   #41
Gopher is offline Gopher  United Kingdom
I've heard lots of good things on the net about 'balanced' headphones too, but when you look at the implementation it's just bridging, not true balanced. I'm not even sure you can have a truly balanced amp with a headphone or speaker as a load - any offers????
Bridging has the advantage of increasing the overall slew rate of the amp, which may be what people are hearing as an improvement, but it doesn't have any of the advantages of true balanced inputs wrt common mode noise and RFI rejection so we can rule them out of the equation.
The major disadvantage of bridging is that the speaker load is halved. This means the amp has to push out more current than it would have to single ended. Chip amps aren't good at that and may run into current limiting problems and distortion due to protection circuits kicking in if the speaker is 4 or 6 ohms to start with. Of course, the effects will depend on which speaker you listen too and so are likely to be variable.
My money would be on a balanced transformer (a top of the line Jensen) input and a well implemented single ended chipamp.
Old 21st May 2010, 05:57 PM   #42
Dear,
Another advantage of a bridged amplifier circuit is, that the load return current doesn't get pumped into the system 0 volt line.
With kind regards,
Bas
Old 21st May 2010, 06:11 PM   #43
Bas
If you separate your signal input, signal output and PSU gnds on a single ended amp and connect them together at a star earth that shouldn't be a problem.
Also, whether or not bridging hits any problems with speaker impedance is more likely to be hit and miss compared to single ended.
Old 21st May 2010, 06:57 PM   #44
Bas
It all depends on your power rails. You can successfully drive low impedance speakers with pair of bridged chips if you keep the power supply rails really low. I am agree that with good grounding scheme's you make a single ended amp silent.
With kind regards,
Bas
Old 21st May 2010, 07:35 PM   #45
If you have a balanced input, single ended output chip amp it can deliver more power, has better load impedance capability and better noise and RFI rejection than a bridged amp.
So the purpose of a bridged amp is what exactly?
Balanced & Unbalanced input with LM3886 chipamp.com JohnnyP00 Chip Amps 5 17th January 2010 02:33 AM
Cheap cable for DIY balanced interconnects? leadbelly Everything Else 4 15th April 2008 03:46 PM
Unbranded balanced cable performance. ashok Parts 0 27th June 2007 03:32 PM
Question about soldering the balanced interconnect cable rnzr Analog Line Level 7 19th September 2006 01:24 PM
Balanced cable and RCA connector: how to wire them? Bricolo Parts 7 31st July 2004 02:10 PM
Page generated in 0.09603 seconds (70.48% PHP - 29.52% MySQL) with 11 queries
