Old 14th January 2006, 10:38 AM   #1
Default How many amps of power does a 3875 with 400VAC need?
I have a power isolator and filter thing I can use but it only puts out 2 amps..... Would that be enough?
Old 14th January 2006, 11:47 AM   #2
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
400VAC kills the chip....
/U.
Old 14th January 2006, 01:22 PM   #3
400VAC transformer with 2x23-26v secondaries in the amplifiers? Hmm Peter uses 400VAC's.....
Old 14th January 2006, 01:54 PM   #4
lineup is offline lineup  Sweden
lineup's Avatar
Maybe you mean the MAINS Filter only puts out 2 Ampere.
That it is rated 2 A
If you have 240 VAC mains this filter can deliver like this power:
Power = Volt x Ampere
P = V x A
volt=240 ampere=2 A
P= 240 x 2
Max Power = 480 VA
That mains filter is okay to put before a 480 VA transformer (max).
With such big trafo, you can easy drive 2-4 LM3875.
A trafo 400VA, 2x25 Volt, will output
400 / (2x25) Ampere
400/50 = 8 Ampere
50 Volt x 8 Ampere = 400 Watt
you know a transformer has two sides
Primary = input side
Secondary = output side
Both sides use formula:
power = volt x ampere
Power what comes in = Power what goes out
240 volt x 1.667 ampere = 50 volt x 8 ampere
Your filter can take 2 A ( at 400 volt max, safety margin )
So it is okay for 1.667 A ( at 240 volt )
lineup
Old 15th January 2006, 01:16 AM   #5
Uhh this filter is a 115v to 115v at 2 amps from the wall, a socket.... This is just to plug things into.
I was going to put a 300-400VAC transformer into the amplifier. There is no filter in the amplifier.
Old 15th January 2006, 03:34 AM   #6
Russ White's Avatar
Send a message via Yahoo to Russ White
I think you are confusing VA with VAC(Volts Alternating Current).
Less pulp more juice Twisted Pear Audio.
Old 15th January 2006, 03:40 AM   #7
Tweeker is offline Tweeker  United States
VA= Volt-Ampere. 1 VA= an amount of reactive power such that the product of volts and amps is 1.
Watts refers strictly to real power, but if you have 100% power factor, a purely resistive load, 1 VA would give 1 watt. This is not normally the case, except with toasters. Generally you want ~twice the VA of your load in DC watts to be comfortable, as rectifiers are an ugly load.
Be sure your foil hat has a good low impedance ground.
Old 15th January 2006, 04:43 AM   #8
None of this is really helping. I am not confused about any thing.
I want to know is 2 amps from the wall, that normally has 15-20 amps is enough to power a 3875 amplifier with a 400VAC Toroidal transformer.
The wall, as in a "plug in" as commonly refered to, puts out 15-20 amps at 115v right (60hz). Well if I have a power filter that also is a isolation transformer that only puts out 2 amp at 115v, I need to know if it can power my amplifier and say a small pre-amp, that uses a PS10 from marchand.
Old 15th January 2006, 05:29 AM   #9
Your isolation transformer is about 230VA (115V*2A=230VA) and will be the limiting factor, but is likely big enough. Going to assume you mean the LM3875 toroid is 400VA (Volt Amps) and not 400VAC (Volts Alternating Current).
If your LM 3875 has a good psu you might not want to use the isolation transformer on it, unless you have DC offset issues or something. Using the isolation transformer will increase the source impedance of your power supply by almost 3 times.
Old 15th January 2006, 05:41 AM   #10
Byrd is offline Byrd  South Africa
Send a message via MSN to Byrd
If you are not confused and you actually intend to power your 3875 with a 400 Volt Alternating Current Transformer then it will certainly be enough as the chip will be blown in a matter of nano seconds and you will need no current past that point.
Ross Saunders
Quad II power amps......power output transformers!!! bwes87 Tubes / Valves 3 10th September 2008 02:20 AM
SMPS for diy audio amps and multi-channel diy amps (and their power supplies) tlparker Solid State 18 31st August 2006 10:39 AM
selling high current power supply for power amps. ericpeters Swap Meet 0 14th January 2005 02:21 PM
FS PA02 Power op-amps +/- 18v, 5 amps modifry Swap Meet 0 11th August 2004 07:45 PM
pre+power amps vs integrated amps pkgum Solid State 4 22nd November 2001 01:46 PM
Page generated in 0.12641 seconds (67.62% PHP - 32.38% MySQL) with 10 queries
