| Chip Amps Amplifiers based on integrated circuits |
Parts Express has a 25V CT power transformer for sale: http://www.partsexpress.com/pe/pshow...number=129-035 "This transformer is a filament transformer. The primary is rated at 115V, and the secondary is rated at 25.2V/2.0A." I was wondering if this trafo would be a good to power LM 3886 stereo amplifier? Alex |
#2 |
Warp Engineer
On Holiday
No it wouldn't. You really want something that is around 2x18-22V secondaries or 36 - 42V CT.
- Dan |
#3 |
Electrons are yellow and more is better!
Max voltage (if you have control over the situation) is 2 x 28 V but it's more safe with 2 x 24 V, then you won't have to think and the cooling requirements gets a bit less also.
/Per-Anders (my first name) or P-A as my friends call me |
#4 | |
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#5 |
the voltage and current are fine but for 8 ohm minimum loads only.
You will need 4 for a stereo amp.. As Peter said 1 per rail per channel. |
#6 |
you could get away with it but as peter said you would need 2. for just a bit more than 2 of those you can get a toroid at 100VA (those are 50VA) from apexjr
http://www.apexjr.com/miscellaneous.html look at the second avel lindburg one in red. i got some, they are nice. they are center tap so you cant use them with dual rectifier PSU such as audiosector or chipamp.com kits unless you modify them (the transformer) i did it and it worked fine. i would use 1 per channel, or it will be a bit underpowered. or start with 1 and upgrade when you can afford it. |
#7 |
Thanks guys. I will pass on this trafo then. Chipamp.com is out of stock on the kits anyway. This will give me some time to get toroidal trafo for the right price
![]() Alex |
| Is this transformer any good for anything? | 38eighteen | Parts | 10 | 23rd December 2007 08:48 AM |
| 17-0-17V/5A good for 3886 GC?? | Triode | Chip Amps | 4 | 18th December 2005 05:18 AM |
| 3886 Transformer wiring stupid question | thermonuclear | Chip Amps | 2 | 16th September 2005 05:38 PM |
| transformer with 3886 (BrianGT Boards) | mantisory | Chip Amps | 2 | 3rd May 2005 02:59 PM |
| Impressions of Snubbered BrianGT 3886 vs Reg 3886 | moving_electron | Chip Amps | 1 | 23rd March 2005 06:51 AM |
| Page generated in 0.08621 seconds (78.40% PHP - 21.60% MySQL) with 10 queries |
