Old 13th January 2006, 03:22 PM   #1
Default Blew an LM4780 chip last night!How?
So last night, I was fooling around with my completed mono amps trying different speakers. I actually had the cd input signal on pause when there where a few bright flashes.
When I looked closely, The 1, 3, and possibly 2 pins were fried!
So any ideas as to what caused it?
I have used the amp for about 5 hours (easy listening) intermittently so far before this happened and the other mono amp is fine, although it is wired the same way???
Thanks,
Dominick in New Jersey
A real amateur enthusiast!
Old 13th January 2006, 03:30 PM   #2
Electrons are yellow and more is better!
peranders's Avatar
What did the "fooling" consist of really? How does the amp and the wiring look like? Some short, loose wire etc?
A LM4780 doesn't pop just like that.
/Per-Anders (my first name) or P-A as my friends call me
Old 13th January 2006, 03:35 PM   #3
Well, I decided to try them on my Martin Logan Clarity's and listened for 1 song, about 3 minutes and then hit pause on the cd player. About 1 minute later, while on pause still, Bada Boom Bada Bing! An indoor lightning show!LOL
I am really clueless. Is it possible that there was a delayed failure reaction??
Dominick
Old 13th January 2006, 03:40 PM   #4
Are any other components damaged?
Old 13th January 2006, 03:43 PM   #5
peranders's Avatar
Did your amp had any output filter? Martin Logan's are a bit capacitive by nature.
Does your amp have any input filter? Maybe HF garbage went through?
Old 13th January 2006, 04:48 PM   #6
The compenents were put together exactly the way they come from audiosector.com!
I did not add any caps or anything else.
So did the ML's burn it?
Dominick
Old 13th January 2006, 04:51 PM   #7
From what I can SEE, nothing else was damaged.
Old 13th January 2006, 05:23 PM   #8
Default LM4780
The ML are a very inductive load, the impeadence at high frequencys can drop as low as .5ohms!!! Chip are prone to high frequency oscillations also. You should always use an input coupling cap with parelleled solutions, also an input network 1k and 22k to ground to set input gain, you need a Ci cap or servo.
Old 13th January 2006, 07:47 PM   #9
Bazukaz is offline Bazukaz  Lithuania
Send a message via ICQ to Bazukaz
It isn't easy to burn these chips , even with hard capacitive/inductive loads.Check power supply , rectifiers , insulation to heat sink.
Old 15th January 2006, 11:57 AM   #10
My heatsink for the chip was touching the mounting plate for the 330 va transformer...but the mounting plate is isolated and it doesn't make actuall contact with the transformer itslef.
Could this be the cause? I wouldn't think so.
Dominick
First chip amp finished - LM4780 bm0rg Chip Amps 14 29th August 2008 09:27 AM
It's time to solder my LM4780 chip G.L. Tirebiter Chip Amps 4 23rd March 2005 05:52 AM
Searching insulator type for LM4780 chip Peter Daniel Chip Amps 10 21st October 2004 12:34 AM
Blew my first Chip ..Oops Help not doing it again? Adam M. Chip Amps 13 6th September 2004 03:08 PM
Night dreaming? / Middle of the night bloom Gabevee Tubes / Valves 54 25th July 2004 04:36 AM
Page generated in 0.11964 seconds (67.22% PHP - 32.78% MySQL) with 10 queries
