Old 10th January 2006, 10:46 AM   #1
Wynand is offline Wynand  South Africa
Wynand's Avatar
Default Volume control acting Up... PLS Help
I've been having a problem.
I built a mono amplifier using the LM3876 chip, just to check the sound quality.
When I play it from my CD-roms headphone out or DVD's headphone out its fine.
When I use a pot at full volume its fine but as soon as I bring the volume down it starts
acting up.
Is this a common problem?
Does anybody have any ideas for me.
Do I need to use a buffer with the input? If so where can I get an approved schematic for it.
P.s. I've used the pot circuit with TDA2050 amps.. no problem
Any help is appreciated
Old 10th January 2006, 10:58 AM   #2
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Default Re: Volume control acting Up... PLS Help
Originally posted by Wynand
[snip]it starts acting up.[snip]
Could you maybe be a little bit more clear???
Jan Didden
/Another new issue: Linear Audio Volume 3!
Old 10th January 2006, 11:16 AM   #3
Wynand's Avatar
It sounds like it starts to buzz/hum.
I don't keep it on for long in case something blows.
Old 10th January 2006, 11:50 AM   #4
janneman's Avatar
If you turn it down, does the sound go down as well in addition to the start of the hum, or does the sound level stay (almost) the same?
Jan Didden
Old 10th January 2006, 11:58 AM   #5
Wynand's Avatar
I'll have to listen 2night at home. I'm @ work @ the moment.
Old 10th January 2006, 12:02 PM   #6
janneman's Avatar
Me too...
Jan Didden
Old 10th January 2006, 12:04 PM   #7
Nordic is offline Nordic  South Africa
Nordic's Avatar
Wynand, inverted amp or not?
Old 10th January 2006, 12:18 PM   #8
Wynand's Avatar
I'm using the datasheet schematic.
Whats the recomended volume pot value and whats the pros and cons of using higher value pots?
Volume control on DVD player remote. Lose resolution at low volume? Circlotron Digital Source 2 10th June 2011 07:20 PM
i need preamp schematics w/o tone control or volume control hernanstafe Parts 7 30th January 2008 03:12 AM
The remote control paratactic volume control audio-gd Solid State 33 7th June 2007 11:16 PM
remote control motorised control for volume pot/knob CharlesY Parts 0 25th July 2005 11:12 AM
Volume control +4db argonrepublic Parts 5 30th April 2005 11:57 AM
Page generated in 0.09619 seconds (73.89% PHP - 26.11% MySQL) with 10 queries
