| Chip Amps Amplifiers based on integrated circuits |
After buying my Son an MP3 player for Christmas I started looking into songs I could down load for him. I really got in the mood to seriuosly listen to music again. I even got the pair of little Bose out of the closet and hooked them up to a small amp and CD player. Knowing that even tho it was enjoyable, the little 5 watter was robing my of the full sound.
So, needing a good amp, I started searching on the net and got into the DIY/Gainclone thing. Since I have a very small budget, I realised that after I got the amp and built it, I would have to save again untill I got the transformer. Then, lo and behold, (this must be a sign ), I had one slapped in my hand from a buddy who had no idea of my new project!So here is the plan. I am convinced that the best way to go about this is to get the LM3875 kit from Chipamp.com. It's a convient pacage with enough left to do that you still feel like you built yourself. For the supply, I have a 250VA center taped transformer that puts out 36 volts to center tap. I have a pair of Bose 201 speakers (8 ohm) that I will use as "close feild monitors". No real intensions to fill up a room. In fact IMHO, close feild monitoring is the best way to hear the sound the producer intended, sense room accoustics hardly inter into effect. Any opinions as to what results I will get, or problems I should anticipate are very much appreciated. Thanks in advance, David Fairmount, GA USA
Poor stereo mix? Switch to mono! Perfect. |
#2 |
diyAudio Editor
Seems like a fine plan. The chip amp will be good enough that you are on a logical path towards a decent system. It won't need to be replaced, so you can next focus on building some good cheap speakers!
The amp will be louder than you expect..
#3 |
Thanks. BTW, the Bose 201s make excellant close field monitors.
#4 |
I would like to ask , what are real advantages of gainclone ?
#5 | |
David, just to check, is the 36V your transformer puts out before or after rectification? If before, it will likely be a little too high for a gainclone, 36x1.41=50V DC.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#6 |
diyAudio Moderator Emeritus
Simplicity, cost, and sound quality.
Trafo might be too high. You want 18-25v trafo for lm3875. edit: doh! the mouse beat me to it.
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.) |
#7 |
'S ok. It's always nice to have backup!
#8 |
Bazukaz and pinkmouse,
Ok so..... Am I back to day one? Help me with this. Is it possible that I could use a Zener to get the voltage down? Or do I need to shop for another transformer? If the latter, does anyone know where I can get one cheap? :-) Thanks to all for posting!!
#9 |
You really need the correct transformer unless you want to get complicated and use a voltage regulator. If you do a search in the chip amps thread you should find many recommendations.
#10 |
Ok, you've convinced me. It's kinda embarassing but, I'm really limited on my budget. I have an ex employer who has a huge surplus of 120/24V single secondary transformers. I'm pretty sure he would let me have a pair. Would that work well? What VA would you recommend for minimum?
Thanks all.
| My TT is finaly ready | IZHAKKATZ | Analogue Source | 10 | 16th February 2009 02:57 PM |
| Ready to Learn | GrahamH | Introductions | 11 | 11th February 2009 08:16 PM |
| My little beast is getting ready.. | johnny1 | Solid State | 27 | 21st September 2006 02:39 PM |
| my new toy, ready to play :) | cowanrg | Everything Else | 3 | 24th March 2005 02:45 PM |
| Ready to build my Gainclone | ebijma | Chip Amps | 34 | 20th September 2004 06:01 PM |
| Page generated in 0.11505 seconds (72.05% PHP - 27.95% MySQL) with 11 queries |
