Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Thread Tools
Old 7th January 2006, 11:57 PM   #1
Default stepped attenuator impedance
Hello.
ive ordered one of these
http://www.diyfidelity.com.au/produc...4ea9ce45cc303f
i chose 100K impedence cause thats what was suggested on the decibel dungeon site. Its for my to-be-built dual mono 3886 (brianGT).
Since reading the post about pots
So I did try all those different potentiometers
i saw Peter used 50K impedence pots, and i assume the same for the attenuator, im worried that my attenuator is too high a value?
Should i call em up and hope they havn't shipped yet or will it be ok. I was planning just passive.
Old 8th January 2006, 05:54 AM   #2
I have purchased one of these attenuators and am very pleased with the results, I think worth every penny. This used with a 3875 from Peter D. I am not able to comment on the value for your 3886 amp, perhaps they will put a hold on it while you investigate?
Old 8th January 2006, 06:11 AM   #3
Greg Erskine's Avatar
hi troublecomes,
I would have selected the 25K or 10K version although I haven't done extensive testing. The attentuator I am building is 20K so I'll be interested in the outcome. My current preamp uses 25K.
I am using a 100K pot on a test rig and I find I have to rotate it a long way to get reasonable volume. I have assumed the value is the problem but I'm open to be enlightened.
So I would put a hold on until the jury returns the verdict.
regards
Greg Erskine
Old 8th January 2006, 06:55 AM   #4
I just finished my Dual Mono LM4780 kit from Peter Daniel and I used a 10k Pot. I dont have a good understanding of Pots, but I only turn it about a quarter of the way around to get the desired listening level usually. Sometimes a little more/less. It works well and I am happy with it.
Hope this helps,
Dominick
A real amateur enthusiast!
Old 9th January 2006, 02:24 AM   #5
Default ta
Thanks guys...
anyone else able to tell me what value i should try for?
I'm not worried about the position of the switch too much, as long as i can get full safe volume out of my amp. Damn, just showed how little i know about this stuff with that last sentence.
Old 9th January 2006, 05:30 AM   #6
Previous to the SA, I was using an Alps 10K pot, I could only use approximately one quarter turn to arrive at a comfortabe listening level
with the SA it will turn a bit more than one half, this gives more low level control as well as much improved sound and better channel to channel tracking. I really like this attenuator.
Old 9th January 2006, 06:09 AM   #7
wchick is offline wchick
I have used 50K noble pot, a 10K taiwan pot and recently a 100K Radio Shack pot on my Gainclone. For the 10K, you turn a little it get loud a lot. For 100K, you need to turn more to get comparable level but as someone said, you get more margin to control the low volume. 50k is more or less in between those two. I think the 100K works fine for me, and I'd never turn to max.
Old 9th January 2006, 12:03 PM   #8
well. i emailed the place for my attenuator earlier this morning and the guy was just packing my 100K one. I made a guess and asked for 50K and im being sent that one. It seems i should be ok from the posts above.
Thanks,
Matt
Thread Tools
stepped attenuator pop Ted205 Chip Amps 17 21st July 2008 03:10 PM
Stepped attenuator sonokeling Parts 0 11th July 2006 10:05 AM
stepped attenuator ivegotmono Tubes / Valves 4 7th January 2006 03:49 PM
Stepped attenuator Bas Horneman Tubes / Valves 24 16th June 2004 08:18 AM
Page generated in 0.27176404 seconds (68.19% PHP - 31.81% MySQL) with 10 queries
Copyright ©1999-2009 diyAudio
