Old 7th January 2006, 11:23 PM   #1
Default is this a good amp kit for newbe
#?¶<new to all this diy amp thing and was woundering if this amp kit was any good for a newbe and if i got two i could make stereo its 100w, i was also woundering if i need any extra parts to make it like power supply (what,how) or any other things i should think about
http://www.dse.com.au/cgi-bin/dse.st...uct/View/K3431
Old 8th January 2006, 02:45 AM   #2
Greg Erskine's Avatar
hi hicksy_5,
This is not a chipamp, so for more info do search for "SC480" and "ETI480" in the solid state forum. A moderator will probably move this thread for you.
This is Silicon Chip's SC480 which is a replacement for the ETI480. A full description can be found in the January and February 2003 issues.
I have built one of these and I was surprised at the performance because I wasn't expecting much from these output transitiors. It's certainly cheap and once you have built one of these you'll be right to try some of the better and more expensive amps.
You do need a power supply, a toriod, a bridge rectifier and some filter caps, plus heatsinks, a case and other miscellaneous stuff. Also look at Altronics and Jaycar which I think do a version of the amp and PSU kit, but not as cheaply.
DS does do a PSU kit.
http://www.dse.com.au/cgi-bin/dse.st...uct/View/K3432
EDIT: I just had a thought, if you are after a chipamp then a Peter Daniel or BrianGT kit (or similar) will be easier to build, cheaper and sound better IMHO, as long as you have reasonable speakers.
Here's a picture of mine, not one of my best efforts but....
Greg Erskine
2 newbe questions Hilly-wa Tubes / Valves 2 15th November 2007 02:24 AM
hi there newbe from uk chrisw38 Introductions 2 27th July 2005 06:28 AM
Newbe alert. snc Multi-Way 2 9th February 2004 03:55 PM
Newbe and first question josefr Digital Source 1 28th March 2003 09:57 PM
Page generated in 0.08778 seconds (62.63% PHP - 37.37% MySQL) with 11 queries
