| Chip Amps Amplifiers based on integrated circuits |
#11 |
Why don't you just unwind some windings to get lower voltage ?
#12 |
Looking for +/- 27 - 30VDC for 4 ohm speakers. 150VA/amp module and 4 total modules - paralleled for 2 channel operation.
Transformer is 600VA, 40VAC -0, 40VAC -0 secondaries, getting 55VDC - 0, 55VDC - 0 after rectifier/12000uF caps. Trying to see if I could "post rectified split" each +/- 55VDC - 0 rail to get two +/-27VDC - 0 ... So in summary, four rails of +/-27VDC - 0 @ 150VA off this transformer via "split"...possible? |
#13 |
There is high probability that this circuit will not work well , but you can try "Simulating" ground.
Resistors should be 500 ohm or so , 2W. This works for op amps , but currents are much lower there. |
#14 |
I attach
the single supply LM3886 circuit, from datasheet. The supply is pin1 and pin4. +V and Ground. You need input( 2.2 - 10 uF ) and output ( 4700uF ) caps. A divider 91kOhm - 100kOhm to bias input. Also a transistor feeding 'GND' pin #7. Several of components are optional. See datasheet comments for more info.
lineup |
| Using split rail supply for single rail DC | DanX | Chip Amps | 1 | 15th March 2008 06:18 PM |
| Using single CT supply with LM3886 | TDWesty | Power Supplies | 0 | 15th March 2007 05:37 AM |
| split rail supply obtain from a single motorcycle battery? | leinahtan | Power Supplies | 5 | 30th August 2006 06:56 AM |
| single supply for lm3886 | xplod1236 | Chip Amps | 5 | 5th April 2004 02:03 AM |
| LM3886 single supply. | unitgain | Chip Amps | 2 | 24th March 2004 01:10 PM |
| Page generated in 0.08441 seconds (70.86% PHP - 29.14% MySQL) with 11 queries |
