| Chip Amps Amplifiers based on integrated circuits |
http://www.overstock.com/?page=proframe&prod_id=1147985
It would look mighty cool to have a pair of these babies powering your amp! I_F |
#2 |
I really wonder if a 1.5F cap can be the size of liter can. Seems like it should be four or five times that size to truly be 1.5F. I have some 59,000uF caps here that are the size of a beer can... granted that they are 75V rated.
#3 |
Yes, this 1.5F automotive smoothing cap seems smaller then it should because of it's low voltage rating. Actually at 24V this one is rather high for an auto cap, most I've seen are 16V.
I don't think a 24V cap is good enough for a "gainclone", and I don't want to know what a cap of that size will do if you give it too much voltage.
The power of Science compels you! |
#4 |
DCIBEL SAID:
I don't think a 24V cap is good enough for a "gainclone", and I don't want to know what a cap of that size will do if you give it too much voltage. HMMM...I would sure like to know and better yet...see it.
A real amateur enthusiast! |
#5 |
I bought one of these once for a car stereo install, tore it apart to see
The guts were sealed in epoxy, it was a bunce of smaller caps paralled in a fancy can with a cheap voltage display pretty much a total rip off..........
#6 |
Good joke, dear I_Forgot!
#7 |
To make one 1.5F/24V cap:
Simply parallel (150)one hundred and fifty 10.000uF/24V electrolytic capacitors. This will give 1.5 Farad. What to use it for? I have no idea, and it will be quite large to fit in an amplifier.
lineup |
#8 |
#9 |
I would so use these if I Wasn't worried about voltage. They can sometimes be found pretty cheap on EBAY. Hmmmmm the aleph X uses low V+, I wonder how a pair of these would sound with that amp.
http://www.caraudioconnoisseur.com/ |
#10 |
http://www.maxwell.com/ultracapacito...app_notes.html
Good for cranking..and helps to reduce dips in car battery voltage...
SivanandBalan |
| Gainclown PCB question | zatramusic | Chip Amps | 31 | 21st December 2005 05:15 PM |
| Page generated in 0.09521 seconds (81.80% PHP - 18.20% MySQL) with 10 queries |
