Old 5th January 2006, 11:39 AM   #1
Chaom1 is offline Chaom1  Estonia
Send a message via MSN to Chaom1
Default problem with tda7294
Hello
I have a little problem with my 2xtda7294 amplifier i just made.
I have to give it input at least 2-3v to get output 20v.
Maximum output i have got is 21v, then the input was 3.5v
So I dont know what is the problem - it should give 30v with 1v input at least. My power sypply is +-32v.
The schematic I used is here: http://www.masterkit.ru/main/set.php?num=540
http://www.masterkit.ru/info/magshow.php?num=48
Of course there is a possibility to lower the r1 (680ohm) to lets say 200 ohm and then rise c3 from 22mkf to 100mkf to save the bass responce. But I kinda dont wanna do that, something must be incorrect about this circuit.
Maybe someone can help me.
thanks in advance
Old 5th January 2006, 11:56 AM   #2
moamps is offline moamps  Croatia
Default Re: problem with tda7294
Originally posted by Chaom1
[B]Maximum output i have got is 21v, then the input was 3.5v
did you check the waveform at the output?
How did you measured the in and output voltage?
Yes. But for 30VRMS at the output, you need almost +/- 50V voltage from your power supply.
What's the output voltage for 0.5V at the input?
Milan
Old 5th January 2006, 12:12 PM   #3
I didnt check the waveform
In and output voltage I measured with usual tester. Output had 6.8ohm 5w resistor in water.
with 0.5v input it has output something 5-7v
Old 5th January 2006, 12:21 PM   #4
but in datasheet there is also capactor there, and in every circuit in the web. If I remove it, i will loose low frequency, the links says. And i have stereo amp and different 100pf capacitors, so one of two should be working great anyway.
but both of the channels act the same...
Old 5th January 2006, 12:33 PM   #5
lineup is offline lineup  Sweden
lineup's Avatar
What frequency did you use?
Many AC voltmeters can not show good numbers at 1000 Hz
If you do not have a special AC voltmeter,
try using 200 Hz or something like this.
lineup
Old 5th January 2006, 02:35 PM   #6
I used my soundcard and later old fm-radio.
Well, im certain that something is wrong since i havent seen an amplifier before what plays 1/3 of its power with my soundcard.
the output is about 700mv.
later the radio output was already 2-3v
Old 6th January 2006, 03:37 AM   #7
sagarverma's Avatar
remove arrowed cap in the image im posting.
its not there in standard schematic.
dont rely on dmm.for as lineup says,dmm response is poor for high frequencies.
Never Underestimate The Bandwidth of A Station Wagon Full Of Magnetic Tapes Hurtling Down The Highway...................Andrew S Tanenbaum
Old 6th January 2006, 12:33 PM   #8
thanks, gonna try it.
Tda7294 e_fortier Chip Amps 2 27th November 2008 01:33 PM
My TDA7294 Amp panson_hk Chip Amps 1 27th June 2007 01:06 PM
Problem with bridged tda7294 CPX Chip Amps 9 31st December 2004 10:08 AM
Page generated in 0.09401 seconds (79.25% PHP - 20.75% MySQL) with 11 queries
