Old 4th January 2006, 11:20 PM   #1
Baracus is offline Baracus  Poland
Default Lm4780 Bridged PCB
Hello
I have a question, where i can find some links to
Bridged LM 4780 PCB Designs, two sided .
Every site has Parallel PCBs.
Thanks in advance
Baracus
Old 5th January 2006, 04:41 AM   #2
sangram is offline sangram  India
Peter's PCBs work fine in Stereo, bridged or parallel. You just have to install/not install certain components to get it to work in the mode you want.
edit: that thread is the "Audiosector" thread in the Vendor's bazaar, or www.audiosector.com
Old 5th January 2006, 04:52 AM   #3
I will affirm that AUDIOSECTOR is a great place to buy.
Peter Daniel is more than willing to assist and is also quick to do so.
I plan on conducting future business with him.
Good Luck,
Dominick in New Jersey
A real amateur enthusiast!
Old 5th January 2006, 05:08 AM   #4
Good Luck,
I agree completely.
Old 5th January 2006, 06:39 AM   #5
Not much changes necessary from parallel to bridge.
see the schematic below
Gajanan Phadte
Old 6th January 2006, 08:48 AM   #6
mmmm Yes, but if you're following National's schema then you'll need to work on Peter's board a bit as it's configured only for non-inverting. For the inverting side you'll have to take input at a specific point, and change some of the resistor values, and not put some at all. It's simpler to have a small inverting opamp at the second input.
Old 6th January 2006, 11:06 AM   #7
jackinnj's Avatar
shameless plug -- see "BridgeClone"
http://www.tech-diy.com/chipamps.htm
and I'll send a reprint of the article.
Old 6th January 2006, 12:45 PM   #8
Send a message via MSN to Silkworm
Talking LM4780 PCB
Here is my LM4780 PCB
Old 7th January 2006, 12:45 AM   #9
troystg is offline troystg  United States
troystg's Avatar
I don't consider that a shameless plug at all since that is EXACTLY what he was asking for.
( I am affiliated only with myself )
Troy
Thinking positive doesn't make things better, it makes you a better person.
Bridged LM4780 Amp jackinnj Chip Amps 19 2nd November 2012 04:17 PM
Parrallel/bridged LM4780 ?? pat allen Chip Amps 5 28th December 2006 04:00 AM
Bridged Lm4780. Up and running. sachi Chip Amps 0 15th December 2005 05:27 AM
Bridged Lm4780. Up and running! sachi Chip Amps 5 14th December 2005 04:37 PM
Bridged lm4780 rs1026 Chip Amps 2 12th September 2004 10:49 AM
Copyright ©1999-2013 diyAudio
