Old 1st January 2006, 02:45 PM   #1
Send a message via AIM to safetyman Send a message via MSN to safetyman Send a message via Yahoo to safetyman
Default Trans for LM4780? Advice please.
I have done a search but after reading thru so many threads but can't get a similar question or maybe it's because I am too noob to recognise it.
Anyway, I just purchased a pair of LM4780 boards from PD and was originally thinking of running it bridged but Peter advice I'll need a balanced source and suggests that I run it in parallel. Now for the EI trans, is one with secondaries of 22-0-22 be right for both the PSU boards or does it need to be 22-0-0-22? And what do I connect to the '0' on the trans?
Apologies if this is too simple a question, but please this is going to be my first project for one who has NO basics in electronics.
Shehzad
Aleph 3 - Diehard fan
Old 1st January 2006, 06:15 PM   #2
Tweeker is offline Tweeker  United States
Secondaries of either 22-0-22 or 2*22VAC would both work. Connections would vary by type chosen.
Running them parallel you might want to use a higher voltage though. 28VAC is about the recommended limit.
Be sure your foil hat has a good low impedance ground.
Old 1st January 2006, 06:23 PM   #3
I recommend you peruase these gainclone pages.
This site has more general audio and electrical information.
Old 1st January 2006, 06:46 PM   #4
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Default Re: Trans for LM4780? Advice please.
It's better ti use dual secondaries with those boards, in case you have a center tapped transformer, connection was explained here: http://www.diyaudio.com/forums/showt...598#post791598
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 1st January 2006, 09:40 PM   #5
pinkmouse's Avatar
I use a 30-0-30 with Peter's boards, and I like the sound with the higher voltage, but they do run warm so you need decent heatsinking.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 2nd January 2006, 08:22 AM   #6
Default Re: Re: Trans for LM4780? Advice please.
Tweeker, thanks for the links. In fact I have been reading up DD's pages and some links to basic electrnoic knowledge. Very interesting and informative. Have to slowly try to understand them as I do not come from neither an electronic or electrical background. Guess there's many more years of reading to catch up on.
Peter, I'll definitely go thru the thread and try to understand what I need to do. Itching to get my hands on the boards and I guess Santa (postal service) is late due to the holiday season. I placed orders for most of the parts with Farnell here, but they are out of stock of everything except for the 10uf caps and the 3.7R 2W resistors. BTW, Farnell doesn't list the 1500uf Panasonic FC caps. Should I go for a value that is one step higher?
Thanks for all the replies, guys.
Shehzad
First chipamp build need advice lm4780 chevy1965usa Chip Amps 10 5th March 2009 10:44 AM
how do I use this trans? whatsnext Solid State 5 10th September 2006 11:48 PM
what trans should I get for 10.4V AC? skseah Power Supplies 1 8th March 2005 01:47 PM
Pot-Trans in a DAC Antonio Tucci Digital Source 4 27th May 2002 11:59 PM
Soz trans. Grasshopper Pass Labs 3 19th November 2001 10:12 PM
Page generated in 0.08717 seconds (77.47% PHP - 22.53% MySQL) with 10 queries
