| Chip Amps Amplifiers based on integrated circuits |
ok i dont know much about regulated psu's except that they "regulate"
i have a transformer and after rectification puts out +-45VDC i want to bring this down to <80V total. i tried using diodes to lose a few volts (2 per rail) but still +-45VDC. my question is what regulators would be the best to use for such a voltage and to use on a couple OPA541 chips?? |
#2 |
The simplest would be lm338's.
#3 |
Οr... like this ...
#4 |
Lets give credit to Rod Elliottt for the above schematic for his pre reg P102
#5 | |
sorry the eshe.... is ok....only resistor value ???? |
#6 | |
Read more here: http://sound.westhost.com/project102.htm
"What is done by what is called myself is, I feel, done by something greater than myself in me." James Clerk Maxwell. 1879 |
#7 | |
I take it you did not put a load on it? There have to run a current thru' the diodes, before they come with the 0.7 volts. So try and put a load on it and see what happens. 10K 1 W should do it for testing.
Best regards Bo |
#8 |
Is this a possible 4 transistor regulator?
Best if average input voltage is: 1.10 x (Vout + 2) to account of eventual mains AC 10% drop. For negative supply transistors are mirrored, NPN to PNP and PNP to NPN. I have difficult to find out values. Especially capacitors values. Values are also much dependent of max output current and amount of ripple at input voltage.
lineup |
#9 |
the +-45Vdc is when you have open circuit load. What is the minimum draw when the circuit is connected? The open circuit voltage will drop as the load increases and may fall just far enough to lie within the range required. Then your diode drops can be used for final adjustment.
regards Andrew T. |
#10 |
i connected psu to a opa541 2 channel amp ( one per ch. ) and the voltage dropped to +-41V still too much i played to loud volume and the least voltage i got was +-40V i dont want to take chances on blowing my chips.are you sure the 338's will handle the voltage?
| Low Noise 3 Leg Voltage Regulators | dsavitsk | Parts | 2 | 10th July 2007 03:49 AM |
| Pre amp voltage regulators help. | AMV8 | Solid State | 19 | 6th April 2007 10:30 PM |
| voltage regulators | GAK | Tubes / Valves | 12 | 25th January 2004 05:34 PM |
| voltage regulators | NAP 160 | Digital Source | 7 | 11th August 2002 10:14 PM |
| Discrete voltage regulators. | JoeBob | Solid State | 1 | 18th March 2002 06:25 AM |
| Page generated in 0.10743 seconds (78.56% PHP - 21.44% MySQL) with 11 queries |
