Old 2nd January 2006, 05:04 PM   #21
ok thanks all
Old 2nd January 2006, 06:37 PM   #22
mateo88 is offline mateo88  United States
Originally posted by AndrewT
Mate88 in post8 gave some bad advice. No.
Connect the transformer centre tap to the smoothing capacitor common. connect a short wire from cap common to central star ground.
Do not connect anything else to the cap common.
Try to keep the routes from transformer to rectifier to cap to cap common to centre tap as ahort as practical. Also keep the area enclosed witin these loops as small as possible.
I'm not sure I follow what you are saying. I've always used the (+) from the negative rail regulator and the (-) from the positive rail regulator tied together for ground.
Old 2nd January 2006, 08:02 PM   #23
Hi mate,
The point where they connect you use as ground.
using the centre tap and cap common as ground.
using the regulator common as ground.
I thought these were two different connection philosophies.
In my opinion it is OK to use the regulator common as part of the star ground. But you must not use the centre tap and cap common as a ground.
Have I misunderstood your first advice.
regards Andrew T.
Old 2nd January 2006, 09:35 PM   #24
I think I just wasn't clear in the first quote. I meant the same thing in both quotes (use regulator common for ground), but I didn't explain the first very well at all. Sorry for the confusion. Maybe I should stop using pronouns.
Low Noise 3 Leg Voltage Regulators dsavitsk Parts 2 10th July 2007 03:49 AM
Pre amp voltage regulators help. AMV8 Solid State 19 6th April 2007 10:30 PM
voltage regulators GAK Tubes / Valves 12 25th January 2004 05:34 PM
voltage regulators NAP 160 Digital Source 7 11th August 2002 10:14 PM
Discrete voltage regulators. JoeBob Solid State 1 18th March 2002 06:25 AM
Page generated in 0.08332 seconds (77.96% PHP - 22.04% MySQL) with 11 queries
