Old 30th December 2005, 07:43 PM   #11
mateo88 is offline mateo88  United States
I believe you can drop up to 30 volts using an lm338, so yes, they will be perfectly fine. Just be sure to use heatsinks.
Old 30th December 2005, 09:18 PM   #12
moutoulos's Avatar
Send a message via Skype™ to moutoulos
How much Ampere give LM338K in 30 Volt output (input 40 Volt) ?
Old 30th December 2005, 11:03 PM   #13
thanks for all your help im going to go for the 338s then.
Old 31st December 2005, 08:00 AM   #14
According to the datasheet, the lm338 has a 5 amp continuous output and can handle 12 amps for very short periods of time (like less than 0.1 seconds).
Old 31st December 2005, 12:51 PM   #15
moutoulos's Avatar
Tnks very much .
Old 1st January 2006, 04:47 PM   #16
but how to use lm338 with dual supply(+-V) not just a positive voltage but a negative voltage too?
Old 1st January 2006, 07:08 PM   #17
You have to use two of them, and run them in series. The point where they connect you use as ground. Nuuk's site has good information .
Old 1st January 2006, 10:35 PM   #18
my trafo does not have dual secondaries it is a CT does the circuit change because of this or no?? sorry for so many questions
Old 2nd January 2006, 04:24 AM   #19
I *think* you should be okay. A lot of CT transformers are really dual secondaries with the windings tied together anyway, so you might want to poke around a bit and see if that's the case. You can desolder the windings from each other and use them as dual secondaries, if you want. I really think you should be ok if you just connect negative to negative rail, positive to positive, and the center tap to the common leads on the lm338's.
Old 2nd January 2006, 08:16 AM   #20
Mate88 in post8 gave some bad advice.
No.
Connect the transformer centre tap to the smoothing capacitor common. connect a short wire from cap common to central star ground.
Do not connect anything else to the cap common.
Try to keep the routes from transformer to rectifier to cap to cap common to centre tap as ahort as practical. Also keep the area enclosed witin these loops as small as possible.
regards Andrew T.
Low Noise 3 Leg Voltage Regulators dsavitsk Parts 2 10th July 2007 03:49 AM
Pre amp voltage regulators help. AMV8 Solid State 19 6th April 2007 10:30 PM
voltage regulators GAK Tubes / Valves 12 25th January 2004 05:34 PM
voltage regulators NAP 160 Digital Source 7 11th August 2002 10:14 PM
Discrete voltage regulators. JoeBob Solid State 1 18th March 2002 06:25 AM
Page generated in 0.08980 seconds (83.31% PHP - 16.69% MySQL) with 11 queries
