| Chip Amps Amplifiers based on integrated circuits |
Hello.
ive just measured the voltage on my transformers that i plan to use for my brianGT 3886. They are supposed to be 22V but when i measured them they are actually 23.5-23.6V and 23.3-23.4 are these going to be ok for a speaker with a nominal load of 6.1 ohms? Even for peak lower ohmage? What about the slight difference between them, will this be a problem/noticable? At least they work, i stupidly thought they were broken when i put the secondries (with no resistance) into the mains and the circuit breaker tripped. I thought about it after i measured the resistance (dunno why i didnt do this first) then felt really stupid. Especially since i posted in the parts section about it. Learning... Thank you. |
#2 |
Electrons are yellow and more is better!
Up to +- 42 volts is OK, technically speaking and around 22-25 V is perfect. Remember also that the voltage will drop when you play loud.
I recommend that to take a look at these docs: http://www.national.com/appinfo/audi...gn_Guide13.xls http://www.national.com/appinfo/audi...sign_Guide.pdf http://www.national.com/an/AN/AN-1192.pdf http://cache.national.com/ds/LM/LM3886.pdf
/Per-Anders (my first name) or P-A as my friends call me |
#3 |
Usually you can measure a little more voltage on a unloaded transformer, so your measurements fits.
Adding a resistor should lower the voltage to - well, close to - 22V. I take it, you were measuring without anything connected and you measured AC?
Best regards Bo |
#4 | |
Notice that you'll get this huge current even with a transformer alone, nothing connected at all at the secondary side!
#5 | |
#6 | |
To simulate this and see what final voltage will you can load the power supply with 2 resistors. I am talking here after rectifier bridge and capacitors. To get around 40-50 mA you should use two resistors 2 Watt rated, 680(for 40 mA) or 470 Ohm( for 50 mA) One between V+ and 0V and the other between V- and 0V. This will simulate one LM3886, and you see what DC voltage supply will be when LM3886 is idle. When you put out power it will sink, as mentioned. If you will use same supply for both, two LM3886 then you should add two more resistors in parallell with the first two.
lineup |
#7 | ||
Best regards Bo |
#8 | |
thanks for the replies
yes measuring AC voltage with no load. Quote:
I havent recieved the kit yet, so ill have to wait to set up that resistance circuit to measure voltage at simulated load. Thanks again -matt |
| 845 Low voltage SE AMP | =maximum= | Tubes / Valves | 8 | 19th July 2007 10:56 AM |
| Should I use high voltage value zeners or multiple lower voltage zeners in series? | jarthel | Parts | 7 | 30th May 2006 04:56 PM |
| Rail Voltage to Capacitor Voltage | Mermprin | Parts | 6 | 20th September 2004 03:56 PM |
| secondary voltage vs. primary voltage | Stocker | Parts | 5 | 11th March 2004 07:41 PM |
| Rail voltage compared to transformer voltage | SteveG | Solid State | 4 | 22nd July 2002 11:50 PM |
| Page generated in 0.17505 seconds (51.14% PHP - 48.86% MySQL) with 10 queries |
